Sponsored by: CARiD
smoky after rebuilt
Old May 6, 2009 | 08:15 AM
ricardo877's Avatar
driftcleveland .com
Cool smoky after rebuilt
Hi just finish mi built on a S5 tII pineapple racing MSP. lapped ,nitrated irons. all seals are new. side,apex. polish rotors, bigger studs, used rotor housings-but on good shape. ported oil pump passages, thermo bypass mod, 200 air jet mod for the eccentric shaft oilers , stationary gears mod new bearings and yes the oil control ring are used but with in tolerances the engine starts an runs like no problem it has run for 3 or 4 cessions of 5 to 20 minutes and it smokes. on mi mind a little less each time.
how much is to much?
what u thing is wrong?
Thanks...
Old May 8, 2009 | 09:46 AM
ricardo877's Avatar
driftcleveland .com
I blo up mi last engine its it posible the turbo is the one smoking? mi spark plugs are coated in light film of oil
Old May 8, 2009 | 12:50 PM
WaachBack's Avatar
Finally Knows
Nothing is wrong, it is normal for a new rebuilt engine to smoke for about an hour after you first start it.
Old May 8, 2009 | 02:38 PM
red87tll's Avatar
needs a cheaper hobby
oil control ring spring in backwards?
Old May 11, 2009 | 08:17 AM
ricardo877's Avatar
driftcleveland .com
Thanks i will kip you posted on the progress lets hop thats the problem...
Old May 11, 2009 | 08:21 AM
ricardo877's Avatar
driftcleveland .com
You think. i make sure it was on the right way, tree sources i check with. will see-what could be the damage if this is the case?
Old May 11, 2009 | 10:38 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
it is fairly normal for a startup engine to smoke initially as has been posted.
two other considerations:
if the surface of your re-nitrided irons is too smooth your motor will smoke forever.
if you ported any of the inner edge of the intake ports that supports the oil ring your motor will smoke.
good luck,
howard coleman
Old May 11, 2009 | 12:15 PM
ricardo877's Avatar
driftcleveland .com
good luck,
howard coleman
the surface was laped after the nitriding.
the iner part of the ports were just beveled for the side seals to ride smooth acording with the pineaple racing MSP tamplets the sharpi marck the iner par just a bit. i thougt it was ok to do...
thanks for your help.
is it posible that mi turbo is damege and that is were the smoke is coming from?
Old May 11, 2009 | 06:33 PM
Barry Bordes's Avatar
"Elusive, not deceptive!”
Is your setup a single turbo?
Where are your vents for the oil injectors connected?
Barry
Old May 12, 2009 | 07:54 AM
ricardo877's Avatar
driftcleveland .com
Barry
yes it is a single turbo gt35r and the oil injectors are connected to the round 4 to 1 splitter and to the back part of the top manifold closes to the firewall.
That is interesting mi friend have a fd and basically same setup turbo injectors porting and hes oil injectors vents are open to the atmosphere?
thanks...
Old May 12, 2009 | 03:46 PM
thanks...
They should be vented to the atmosphere! You are sucking all of the oil out of the injector at idle...... than when you get on the boost it will take some time before the rotors are getting any oil! "Bad karma"as Lynn Hanover would say.
Pop off one the filter vents that are used on your old solenoids and stick that on the lines for a filtered vent.
Barry
Old May 27, 2009 | 07:57 AM
ricardo877's Avatar
driftcleveland .com
Thanks to all
So I opened mi engine just to find that i went to town on the ports. that was mi problem, i was able to reuse all of mi seals and wallah no smoke. thanks to all for your support and advice
O and I went with stock ports on the intake and MSP on the exhaust any advice or suggestions?
James Knox
Oct 5, 2015 07:56 AM
