RX-7 Stalls in Summer!
Old May 29, 2002 | 07:57 AM
Newbie
85 RX-7 GS 12A Carb. Engine Approx. 110k miles.
Problem: My rx-7 has developed a 'summer only' problem that is about to drive me crazy! It must be heat related, but here is the scenario almost every time; Hot summer day, drive car fairly hard, stop for a quick stop (10 minutes or less) - get a drink or something - restart car and within 2 minutes car quits!! No warning, just stops. The car has to sit for at least 1 hour before it will restart. Restarts like nothing ever happened. It has happened at least a dozen times over the last 3 or 4 years and I have decided to fix it this summer. Took it to the dealer and they wanted to replace clutch!!!!! I may not know a lot about this car but I am not stupid! Never has stalled prior to making stop and shutting engine off for a few minutes. Very odd. No warnings, no lights, no buzzers, just quits. I suspect something controllling fuel or spark is the culprit. I have done all the simple stuff like filters, plugs, wires, caps, etc. but have not changed coils or fuel pump yet. Any suggestoins out there?
Old May 29, 2002 | 08:33 AM
yayarx7's Avatar
Are you Nucking Futs?
sounds like vapor lock. I have never heard of a first gen suffering this, but have heard of other cars. make sure the fuel lines are routed well away from any heat source, ie heater hose, exhaust. And make sure your carb heat shield is there and functional, finally change the petrol you are running.
Old May 29, 2002 | 09:22 AM
Directfreak's Avatar
I am a Jeeper Now.
Yep. Is your fuel lines next to something really hot? Your fuel might be boiling and causing the vapor lock.
Old May 29, 2002 | 11:34 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
My 80 used to that **** all the time! Drove me nuts, but when I rebuilt the motor and changed out to a newer carb it didnt do it anymore... Not saying its the motor, it is probally in fine running shape... Id say look at the other suggestions, including maybe a carb rebuild?
Old May 29, 2002 | 06:03 PM
85RX7GS's Avatar
Get rid of the altitude compensator and check the sensors.
Old May 30, 2002 | 09:24 AM
crankit's Avatar
Do a search on Hotbot for vapor lock . Good info
toplessFC3Sman
Mar 20, 2018 01:54 PM
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
REX7&Z32TT
Sep 9, 2015 05:16 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
