HELP, engine acting weird.
Old May 28, 2002 | 06:36 PM
slipperyslater1's Avatar
Had a leaking radiator. Tried the sealant stuff. Now all of a sudden when the car warms up and I give it gas, the check engine light comes on and it spits and sputters when I get it up at about 3000 rpm. All the while, starting perfectly, idling perfectly, and showing no champagne bubbles of death. I've tried resetting everything and researching this, but can't find any help. Anyone ever heard of anything like this? All advice appreciated. Thanks, Mark
Old May 28, 2002 | 06:37 PM
mjw's Avatar
mjw
Is your map sensor hose disconnected?
Matt
Old May 28, 2002 | 06:39 PM
I don't think so. Could it be some sort of other sensor clogged or something?
Old May 28, 2002 | 06:40 PM
Rx-7$4$me's Avatar
your car could be in limp home mode, try resetting the ECU by disconnecting the battery and holding the brake down for a good min and reconnecting it.
Old May 28, 2002 | 06:41 PM
Rx-7$4$me's Avatar
does it feel like you hit fuel cut when u get to 3000 rpms, kinda like you hit a lock at 3000 rpms like a minny rev limiter heh
Already tried that.
Old May 28, 2002 | 06:42 PM
I'm not sure what that is like. Don't think I've ever hit a fuel cut.
Old May 28, 2002 | 06:43 PM
Where is that map sensor, and I'll go look real quick.
Old May 28, 2002 | 06:44 PM
mjw's Avatar
mjw
It is on the driver side on the firewall, just behind the AWS hose that connects to the intake elbow on the throttlebody.
Matt
Old May 28, 2002 | 06:45 PM
mjw's Avatar
mjw
Just a thought as well, if you have a leaking radiator you should really replace it.. I know it is all a matter of $$$.. never seem to have enough of it.
Matt
Old May 28, 2002 | 06:49 PM
I'll go check it now. Yeah, I want a fluidyne. Looking for something used, now.
Old May 28, 2002 | 06:53 PM
Does it say sensor-boost, on it?
Old May 28, 2002 | 07:03 PM
Old May 28, 2002 | 07:10 PM
Hose is on. Anyway, it doesn't feel like a rev limiter. It feels like it wants to go but it starts bogging down, backfiring and all. Like something is clogged, is all I can say.
cristoDathird
28
May 30, 2019 08:47 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
TerryD
Aug 23, 2015 07:40 AM
