White smoke at start up
Old Apr 25, 2009 | 08:22 PM
nh256's Avatar
When i first start my 84 gs in the morning, white smoke always appears about a minute after ignition. I ran a compression check when I first got the car and it read 96/100 on all four plugs. I realized the plugs were burning up faster than what they should be. This usually means it's a carburetor issue right? Any advice?
Old Apr 26, 2009 | 08:24 AM
Go48's Avatar
Sounds like you used a conventional compression tester and just took the overall reading. That will not tell you much about the health of the engine. You need to do a compression test that gives you readings for each face of each rotor--i.e., 6 individual readings. For information on how to do a simple compression test, go to: http://www.aaroncake.net/rx-7/blown.htm. Otherwise, find someone with a compression tester for rotary engines and have a proper test done.
The white smoke may be an indication of failed internal coolant seal(s). That is, if it is truely white, is a wispy water vapor versus smoke, and it has a sweetish smell. However, if the ambient condition was cold and damp, it may just be condensation as the hot exhaust gas comes into contact with the cold, damp air. Or if it is really smoke and it is really a slightly bluish color, that might indicate excessively rich air-fuel mixture or excessive oil in the fuel.
Not sure what you mean by plugs burning up. What color is the center insulator after you have run the engine? If brownish/tanish, you're good. If black, your air-fuel mixture is too rich. If white, your A-F mixture is too lean or you have coolant entering the combustion area.
Old Apr 28, 2009 | 02:38 PM
fcs3l0ve's Avatar
No Pistons!
sounds like your coolant seals are blown or its just burning off condensation.
Old Apr 28, 2009 | 07:48 PM
joconnell's Avatar
coolant is generally the problem if it happens everytime, regardless of your outside temperature, warm or cold.
condensation can be a factor for wisps like poster 2 suggeste, just as the said, it can happen when its cold.
Old Apr 30, 2009 | 10:37 PM
CAPTN_SLAPPIN's Avatar
cock block ransom
check for threads posted by kentetsu... he used this thing called alumiseal.
Old May 2, 2009 | 10:37 AM
fcs3l0ve's Avatar
No Pistons!
alumaseal works and so does blue devil sealant. thats what I used and it solved the problem for me.
Old May 2, 2009 | 11:52 AM
mar3's Avatar
Administrator
Not sure what you mean by plugs burning up. What color is the center insulator after you have run the engine?...If white, your A-F mixture is too lean...
Pretty much always the answer regarding the white "smoke" on start-up in the morning...UNLESS, of course, it never goes away during the whole drive...then you're in trouble. I've never burned up spark plugs, they generally just wear out in two years or so....they're worn out to me when the car won't start anymore...time for plugs!
Mario III
Old May 5, 2009 | 08:38 AM
baz_392's Avatar
can you smell antifreeze in the exhaust?
Old May 5, 2009 | 10:51 PM
jamie97M1's Avatar
White smoke usually means coolant being burned. Does the exhaust smell sweet??
Old May 8, 2009 | 02:37 PM
mainlymazda's Avatar
Newbie
Red face White Smoke
If it is truly white then it is definitely water. A couple possabilities exist.
It is either real expensive because the engine was overheated or it could just be a bad seal.
One area that is overlooked is the o-rings that go between the intake manifold and the housing. It may be leaking when cold. This is usually from corrosion of the rotor housing or intake manifold.
Using a stop leak is a short term fix. It may hold off leaks for a while, but eventually you will need to do something to the engine.
Sorry, it's not better news but that is the reality of it.
Jutta_J
Mar 25, 2017 11:24 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
NCross
Sep 3, 2015 03:42 PM
