Which Oil Line Goes Where???
Hi.....I'm need of a little help with the oil injection lines. Which one goes where? I have the manual but its really blurry and I can't tell where they go. Also, they are stainless lines, not the factory ones....the factory lines have color coded dots on the ends......but I sold the oem lines. Thanx in advance
Well if you had factory lines it would be obvious, they only fit one way.
Either way it doesn't matter, both oil lines are going to flow the same amount of oil, plumb them in so they look/fit nice.
Jeff
Jeff
Well, I know they are supposed to go in order. One goes to front rotor housing and the other to rear rotor housing. The oil injection into each housing I would think would be at different time intervals because of the rotors being at different spots during intake/compresion/combustion/exhaust......therefore the reason for having colored dots on the lines....so they go where they are supposed to and they inject oil at a specific time as the rotor wobbles....PLZ...somebody has to know for sure...Thanx
Trending Topics
