Sponsored by: CARiD
oil pressure ant stedy? HELP
Old Apr 22, 2009 | 07:36 PM
LongsTurboFB's Avatar
Rotor or No Motor
NC oil pressure ant stedy? HELP
Hi I Just got done buiding a 12A bridgeport, It runs great but now at 200miles I just seen that the oil pressure is acting weird. When I first started the motor it had 70-75psi of oil but now when it is idling it is at 60-65 but when I give it some gas and hold it at 2,500rpm it will go to 70 but not stay at 70 then at the same rpm goes back to 60-65 psi and if I run it hard and high rpm I have seen it drop to say 55psi, but when I let out of the gas it goes back to 60-65 is that normal with the motor seating in ? I think that mabe the sending unit is bad or I need to bafel the oil pan so the oil stays in one spot, then moving front to back of the pan. So if you can help me some info would be cool Thanks your rotary friend Josh.
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
