headlight wont go down
Old Apr 22, 2009 | 11:04 AM
Jonnelle's Avatar
my driver side headlight wont go down. the other headlight goes up and down just fine. any ways everytime i turn the headlights on and off there a buzzing sound coming from that headlight. is it a motor / ground / rrelay issue? thanx in advance
Old Apr 22, 2009 | 12:45 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Sounds like a loose connection inside the motor/up-down slide relay
Old Apr 22, 2009 | 12:53 PM
another7driver's Avatar
Listener
Try manually moving the headlight with the screw under the car. If it moves it's going to be an electrical problem since the motor appears to be turning from your description.
Old Apr 30, 2009 | 12:55 AM
Jonnelle's Avatar
k so i went to try manually close the headlight but realized the **** was missing. i was pretty convinced it was motor so i just went out and bought a working one and now its fine. thanx for the help everyone. appreciated =]
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
