Microtech Is 15 degrees to much advance at idle?
Old Apr 22, 2009 | 09:08 AM
Rotary?Cool's Avatar
top row 2nd from left..me
I have been trying to solve a cold start issue on my car forever. Last night for ***** I set the T RPM setting at 500 rpms to 15 instead 10 and got a much quicker start. Is 15 too much for idle? What would be the limit of advance at idle?
Thanks
Old Apr 22, 2009 | 01:39 PM
Aaron Cake's Avatar
Engine, Not Motor
15 degrees is about where I start for idle advance. Generally I find engines are a lot happier from 15 to 18 degrees at idle then where most people place them.
The limit depends on your engine and setup. You can advance idle timing and adjust fuel accordingly (generally pulling it) until the idle becomes unstable or you have to start adding fuel to keep EGTs from heating up (or the engine from running lean AFRs).
Ports with more overlap like bridges like a lot more timing with a lot of split at low loads.
Old Apr 22, 2009 | 02:08 PM
Yeah, I definetly had to remove some fuel at idle after uping the timing. When cranking I get a healthier start then before, I havent tried it completely cold yet but I definetly liked the way it responded to the change. I will experiment a little more today with more timing, take it up to 18 and see the results. I will monitor the EGTs as I make the adjustments.
My idle EGTs are around 900 and cruise around 12. Idle AFRs are mid 13's cruise are 14's I belive I can go leaner. EGT bung is at the rear about 2" from the port.
Thanks for the input!
Old Apr 22, 2009 | 10:20 PM
pistones's Avatar
i am running 20* of advance at idle, that's where my engine seems to be happy. i have tried lower but it just idles crappier, i am wondering when is it too much?
Old Apr 24, 2009 | 10:33 AM
Aaron Cake's Avatar
Engine, Not Motor
Too much is when it starts to become crappier again, you need to add fuel, or you burn out plugs.
Old Apr 24, 2009 | 10:40 AM
I tried 20 last night, it smoothed out the idle a little bit more. The switch from 18-20 kept the switch from 15 to 10 HG at idle from being so lumpy. Something I couldn't tune out with the fuel.
Old Jul 29, 2010 | 12:31 PM
cbrock's Avatar
mine is set at 22* at idle
Old Jul 30, 2010 | 02:19 AM
rx72c's Avatar
Top Answer: 1
15 degrees is fine. on my heavily ported street port engines i run 5 btdc otherwise you get a lumpy idle.
Old Sep 18, 2010 | 08:05 PM
jamespond24's Avatar
How about half bridge motor, I'm running 20*? What do you recommend?
Old Sep 18, 2010 | 08:27 PM
joeylyrech's Avatar
87 SE WITH S5 T2 SWAP
me 2.
I am wondering the same thing,right now i have my HB at 1500 rpms and 15* and is a little rough,I will like it to make it idle well brap a little better.m
Old Sep 19, 2010 | 10:35 AM
Aaron Cake's Avatar
Engine, Not Motor
With a half bridge, try around 18 degrees and 15 degrees of split. Of course the Microtech's crappy timing setup might not allow you to run 18 degrees at idle without effecting other areas of the map...Shoot for an AFR in the low to mid 13s.
Old Sep 19, 2010 | 09:30 PM
rx72c's Avatar
Top Answer: 1
half bridge around 20 degrees is good.
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 15, 2015 04:45 PM
RotaryBobby
Sep 10, 2015 01:33 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
rx7shirley
Sep 2, 2015 02:11 PM
