kinda stumped
Old Apr 21, 2009 | 10:31 PM
JoshUsherwood's Avatar
kinda stumped
i have 1983 1st gen gsl. Me and a friend have been trying to get it up and running but we keep running into the same problem. It'll crank, run, and then cut off after about 10 seconds. it doesnt really make sense. sometimes it'll just spin when holding the key and pumping the gas, when other times itll crank right up. I have a good spark, we've just cleaned the floats and the chamber for the floats, and cleaned the fuel lines in the carb. we've noticed that the secondary jets fill their bowls, but sometimes not the primary's. even after cleaning them.
could this be the result of the old and rusted fuel pump? or am i missing something? like we've had it running where it would stay running with my foot on the pedal, and we had it going for 5 minutes straight till we tried to let it idle multiple times one day. it'd die after we took out foot off the gas, but that is probably because we have to adjust the idle screw. but now it wont do it again.
Old Apr 22, 2009 | 01:01 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Could be the pump, but unless you took about 3 hours to clean the Carb, it is still dirty.
The stock Nikki carb is very complex inside.
Old Apr 22, 2009 | 08:30 PM
yeah,we only took the top off to get to the floats, and cleaned them for about 30 minutes. haha. but what else should i look into in diagnosing it?
Old Apr 22, 2009 | 09:26 PM
Rx7_Nut13B's Avatar
You need to rebuild the Carb, the local auto parts can get the rebuild kits quick.
It is got to be the carb
If you want to see if it will run longer, use starter fluid as the fuel, just keep spaying it in there as it is running
Old Apr 22, 2009 | 09:37 PM
it does run longer when i use starter fluid or even carb cleaner as fuel. so its gotta be the carb for sure?
Old Apr 22, 2009 | 10:01 PM
Rx7_Nut13B's Avatar
Yep
Old Apr 22, 2009 | 10:03 PM
alright. im not too sure about rebuilding it, but im gonna pick up a kit tomorrow and try. hopefully its not hard. while im at it, im gonna get rid of all the unnecessary emissions stuff on it too.
c0rpse
16
Sep 25, 2015 11:33 AM
Barry_Beef
Sep 22, 2015 06:36 PM
Donald Hampton
Sep 17, 2015 03:13 PM
