thoughts on dual digital EGT gauge
Old Apr 19, 2009 | 09:50 PM
13bturbofc's Avatar
mmm doritos
Question thoughts on dual digital EGT gauge
Hello, i just got a new long runner tube manifold and i had them weld in a EGT bung on each runner right at the engine flange. So im looking for a really nice (fast acting) dual egt gauge to assist me in tuning the car and getting the timing set perfect. Im almost sold on the spa dual digital egt gauge but damn its $500 ****** bucks!!. i was also looking at the koso unit but its oddly shaped since its made for snowmobiles and other 2 strokes. anyone have any expiriance with the SPA unit? here is a link..http://www.pegasusautoracing.com/pro...asp?RecID=2942
Old Apr 19, 2009 | 10:06 PM
catch-22's Avatar
pineapple racing had a dual EGT setup, dont know if there still selling it, but you could check there site.
Old Apr 19, 2009 | 10:09 PM
13bturbofc's Avatar
mmm doritos
yea but thats an analog (needle) gauge..very slow
Old Apr 19, 2009 | 10:12 PM
13B-RX3's Avatar
7s before paint!!!
http://www.cpcracing.com/site/256083...edline%20Gauge
With the exposed tip probe it is SUPER fast responding!!!
Old Apr 19, 2009 | 10:51 PM
13bturbofc's Avatar
mmm doritos
im assuming that gauge doesn't come with probes or the boxes?
Old Apr 19, 2009 | 11:32 PM
13B-RX3's Avatar
7s before paint!!!
When i bought mine directly from the manufacture it came with everything. There are no need for boxes, the sensors plug straight into the gauge.
Old Apr 20, 2009 | 01:08 AM
Evil Aviator's Avatar
Rotorhead
Slow-acting thermocouples (the sensor part) are the primary factor in slow readings. Slower thermocouples usually have a response time of 4 to 7 seconds, while faster thermocouples respond in 0.3 to 0.75 seconds or less. Special gauge circuitry can reduce the indicated lag by trying to anticipate the reading based on the sensed rate of change. Since thermocouples work by generating electricity, all EGT gauges have at least some portion of electric guts regardless of the display type. For rotary engines, make sure your EGT gauge reads at least to 1700F.
I have SPA gauges, but unfortunately I have not been able to try out the EGT gauge yet. I can tell you that the SPA gauges are very well made. The programmable warning light is most valuable function on the SPA gauges, although that would not make as much difference for EGT as it does for the other gauges.
Old Apr 20, 2009 | 06:40 AM
13bturbofc's Avatar
mmm doritos
ive read in a few threads that with the needle gauge there is a bit of lag compared to the digital, even with the faster thermocouples. I dont have any open gauge pod spots so im leaning more towards the koso gauge which comes with fast probes and i can mount it on the column or under the dash near the steering column. also i love how the display slowly changes to red at high temps..
Old Apr 20, 2009 | 09:46 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
gauges work really well for indicating water temperature or how much gas you have in your tank.
tuning?
not too well.
sure, if you want to just get a peak reading at the top of your RPM. as far as tuning you really need an EGT reading to the degree in each of the Power FC/Datalogit's 400 cells.
perhaps it's just a question of what you want out of your EGTs. given that my setup w front and rear rotor EGTs cost less than $200...
as i have previously posted, during my last dyno session we found what we wanted (1550-1625) at one bar and up but looked at 0 to one bar and found we were in the 1200s... w perfect AFRs. so we added timing in that range til we had 1450 and gained a bunch of midrange. meanwhile the AFRs didn't budge. we couldn't have gotten it done if we didn't have logged digital EGT data.
h c
Old Apr 20, 2009 | 03:08 PM
BluRR's Avatar
Howard your setup cost less than $200 but it requires a datalogger like the datalogit to read the results correct? I dont have a datalooger what would you recommend then?
Old Apr 20, 2009 | 03:10 PM
BluRR's Avatar
Oh btw i run a microtech
Old Apr 20, 2009 | 04:42 PM
13bturbofc's Avatar
mmm doritos
same here, i have a microtech. so i figured id at least buy a gauge to see if my rotors are in balance.
Old Apr 21, 2009 | 11:25 PM
arghx's Avatar
rotorhead
I have the FJO EGT-to-analog converter for datalogging. it's a compact, nice looking unit with good instructions and a detailed chart of signal output voltages.
streetlegal?
Mar 17, 2022 02:46 PM
sYnth.
Aug 19, 2015 06:27 PM
