rear main seal leaking
Old Apr 18, 2009 | 06:05 PM
instrumetal86's Avatar
just picked up a 93 FD from a member. noticed some wetness on the bottom of the car, and it appears the rear main seal is leaking. it has already been replaced within the last year or so.
anyone else have a similiar problem or advice? thanks
john
Old Apr 19, 2009 | 05:56 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
It isnt the rear seal, it is the oil pan. This is a normal problem with the FD's. Most people just have to live with it, it isnt going to hurt anything
Old Apr 19, 2009 | 06:34 AM
thanks for the info. i did notice the bottom of the pan was wet as well. just curious, why is there no real fix?(or a long term one)
Old Apr 19, 2009 | 07:10 AM
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/mythbusters-time-oil-pan-motor-mounts-488739/
anyone had luck with using RTV sealent as described here?
Old Apr 19, 2009 | 08:12 AM
dgeesaman's Avatar
Yes, if you use the right RTV and you follow the tightening procedure.
Dave
Old Apr 19, 2009 | 09:21 AM
thanks, what rtv is recommended?
Old Apr 19, 2009 | 10:14 AM
Aaron Cake's Avatar
Engine, Not Motor
I generally use Permatex Copper silicon gasket goo. This is in FCs though. From what I understand the FD is more leak prone. On FCs anyway, I always replace the bolts with some about 1/4" longer and then use wide fender washers to distribute the load. A skim coat of goo on each side of the gasket and I have not had one leak yet.
I've heard good things on this forum about using Honda Bond, but never tried it myself.
Old Apr 19, 2009 | 11:58 AM
dgeesaman's Avatar
Hondabond or Permatex's "The Right Stuff" are preferred on FDs.
There are other tricks like an oil pan brace, dimpling the flange, etc to improve the seal further. There are links to this information in the 3rd Gen FAQ.
Old Apr 19, 2009 | 12:39 PM
thanks for the info guys, will try this on the next oil change
Th0m4s
Feb 26, 2019 02:04 AM
