Megasquirt I need a map
Old Apr 18, 2009 | 08:50 AM
nu-rx7junkie's Avatar
Cool I need a map
Ok, I have looked in the forum for a map and settings and one thread says this and another says that. So maybe some folks will share with me if I ask. I have the following.
ms2 v3.0
dual vr circuits
stock ignition
ms2/extra 2.1.0o for code
550cc primaries
1600cc secondaries
Holset hx52 turbo
Half-bridge port
efan
I think thats all you need to know.
If anyone has a map avaliable for this let me know. I just need some thing to start with. Thanks everyone
Old Apr 20, 2009 | 05:04 PM
hkp's Avatar
hkp
big turbo spoolin
you also need to know what bar map sensor if its anything like a haltech
Old Apr 20, 2009 | 09:49 PM
I'm using a rsautosport 4bar. So your using a hx52 as well. You know megasquirt? I need some help if so. I hooked up the ms2 to my car finally and I have no rpm signal. Sucks. I think its the 2nd vr conditioner, i used the jb perf board on my ms2. Then after i built it and installed it the ms2 faq showed up and shows a different schematic for the ms2 than ms1 a fact that was not easily found before the faq. So guess since they are different im going to have to look at the board and see if i can jump the unused parts and get a working signal. Everything else I have traced twice and no problem found except the vr circuit.
Old Apr 21, 2009 | 07:05 PM
hkp's Avatar
hkp
big turbo spoolin
i run a haltech because thats what my tuner likes, you should get one, im sure he would tune your car, he operates in austin as well, out of a place called protech performance.
Old Apr 21, 2009 | 11:16 PM
John? I have talked to him before,but not about Measquirt.
I ditched the dual vr circuit today and used a spare cas shaft and chopped 2 teeth out and reset the ignition settings and tried to crank the car over to check rpm and it started and died!!! Dont sound like much but big improvement from no signal. So think a need to get the fuel settings right for cranking and idle. Also need some spark tables to input. Little bit at a time.
Old Apr 25, 2009 | 06:39 PM
K New up date
map for 2.0.1 modded cas, 550cc 1680cc injectors
4bar map sensor, stock coils and ignitors
half bridge Turbo
Anyone have a map?
I have gotten close to being able to idle, hmm thats is lol
Old Apr 26, 2009 | 11:18 AM
muythaibxr's Avatar
MegaSquirt Mod
You should use the latest 2.1.0 beta firmware. That fixes some bugs with the rotary engine that may help you get your engine started and running better.
Ken
Old Apr 26, 2009 | 05:29 PM
Ok Im about to load the 210o firmware. Any maps now lol. Wish me luck!
Thanks
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
