problems with accelration
Old Apr 15, 2009 | 10:09 PM
rookkwst17's Avatar
i started having some problems where when i rev my rpms it won't rev past 3000 and seems to pulsate this came out of nowhere and have now idea. lookng for suggestions thanks it starts just fine and idles okay you wouldn't know there was a problem until you give it some gas
Old Apr 16, 2009 | 10:09 AM
another7driver's Avatar
Listener
what series? turbo/na?
My first thought would be secondary injectors dirty/failing but we should have a lot more information to help diagnose this issue.
Old Apr 16, 2009 | 10:36 AM
rookkwst17's Avatar
it's an 87 NA not sure of the series.
Old Apr 17, 2009 | 01:01 PM
rookkwst17's Avatar
this problem workd itself out
Old Apr 17, 2009 | 02:28 PM
Aaron Cake's Avatar
Engine, Not Motor
And the cause was?
You are likely facing a bad ECU ground at the engine.
Old Apr 18, 2009 | 01:24 AM
rookkwst17's Avatar
not sure let it set over night tried it the next morning hasn't happened again.
Old Apr 18, 2009 | 04:15 AM
EvilRB's Avatar
glad it worked it's self out but try some injector cleaner anyways just in case.
Old Apr 18, 2009 | 08:38 AM
rookkwst17's Avatar
thanks for the reply. i put some seafoam in it and filled up the tank
Old Apr 18, 2009 | 08:39 AM
Skaterking's Avatar
I like them top down
Did you recently wash the car? Or did it rain?
Old Apr 18, 2009 | 08:40 AM
rookkwst17's Avatar
nope
Old Apr 18, 2009 | 10:34 AM
Aaron Cake's Avatar
Engine, Not Motor
Injector cleaner won't help. It's nothing but snake oil.
An intermittent problem will reoccur again, probably at the worst time possible.
A good first step is to check your grounds:
http://www.aaroncake.net/rx-7/grounding.htm
Old Apr 19, 2009 | 10:31 AM
rookkwst17's Avatar
i'll check the grounds as soon as i get this other problem worked out. you guys are awesome this forum has been a big help.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
