Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek AWS Output
Old Apr 12, 2009 | 02:53 PM
solareon's Avatar
AWS Output
I got an s5 na with the stage 2 upgrade.
Does having the aws output hooked up to the aws solenoid and then triggering it at a certain rpm like 5k or so provide any tangible airflow/hp difference? I think it should because it pulls air behind the afm and then dumps it behind the tb.
I turned it on and set it and it does work but I don't know if it actually doing anything under a load.
Old Apr 30, 2009 | 10:52 AM
arghx's Avatar
rotorhead
it won't do a dang thing. the AWS solenoid is fed by metered air... you are just rerouting it
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
befarrer
Sep 22, 2015 09:33 AM
