question about the carburetor
Old Apr 12, 2009 | 12:52 PM
shootermain's Avatar
ok i got my hands on a 1985 gs.. this kid messed up alot.. hes 17 and had his priorties backwards. anyways.. he put a holley carb on there and im having trouble trying to figure out how to hook up the other things from the car... the choke the oil feed lines and the oil feed pump cable. what can i do to get this carb properly installed. i finally got it started but when i gave it some gas it seemed to flood.. please help
Old Apr 12, 2009 | 04:32 PM
lascelles's Avatar
sell the Holley to a 17 year old and get a Nikki.
There was this old coot in upstate New York selling rebuilt ones.
He pretties them up a little much. but they work.
His name is Sterling
Old Apr 12, 2009 | 05:44 PM
vipergts_3's Avatar
G0D OF DEATH
http://sterlingmetalworks.com/
Old Apr 12, 2009 | 07:25 PM
blackdeath647's Avatar
weak minds wear the crown
or get an FPR so you can get less gas to the carb
Old Apr 12, 2009 | 07:40 PM
i do have a fpr...
Old Apr 12, 2009 | 08:35 PM
SCCAIT7's Avatar
First of all if he just threw a random Holley on its quite possible that it needs rejetted. This is expecially true if it will idle but not rev - The car is just getting way to much gas. Is the choke manual or electric? If its electronic just wire it up and put it somewhere thats easy to get to when you start it. The oil lines - This is where I would encourage you to start mixing your gas/oil. There are a number of different two cycle oils out there - Your choice... depending on how much you want to spend per gallon. 5oz per gallon of fuel.
Old Apr 12, 2009 | 08:47 PM
OneRotor's Avatar
RAWR
1 oz per gallon of fuel. Stock mix ratio is something like 150:1. I used to do 1 oz/gallon, so 128:1. You are recommending 25.6:1. Richer than almost any true 2-stroke engine. You will foul your plugs. Alot.
Get rid of the Holley and get yourself a Sterling, with a Carter pump and a Holley FPR, with a gauge from Billy at ReSpeed. You'll thank yourself.
Old Apr 13, 2009 | 12:01 AM
risingsunroof82's Avatar
AKA mrwankel82
Yeah, 5 oz to a gallon is WAY too much.... I do the same as whitey, 1 oz to 1 gallon of fuel. And I got a holley.......... they're not bad at all!!! Of course I'm having trouble right now but thats not the point........ I need a rebuild kit. Set your FPR to 5.5-6lbs I suppose. The racing beat setup wants 6 I do believe..... what CFM is the holley he put on?
Old Apr 13, 2009 | 01:02 AM
OneRotor's Avatar
RAWR
I had the RB setup on my old FB. Pulled like a train when the secondaries would work. However, it's probably just some random Holley that isn't modified to work on the 12a, so he should get rid of the Holley and go with a Sterling. His performance will be comparable to the RB setup and it'll be less expensive.
Old Apr 13, 2009 | 05:36 AM
Kentetsu's Avatar
If you can afford about 400 bucks, then definitely check into a Sterling carb. If you're looking for high performance, that is. Otherwise, grab a used Nikki and throw a rebuild kit on it..
Old Apr 13, 2009 | 12:24 PM
AKA mrwankel82
Where can we buy a sterling? So are they as good if not better than a holley?
Old Apr 13, 2009 | 02:41 PM
OneRotor's Avatar
RAWR
look at the link above...
Old Apr 13, 2009 | 03:47 PM
the choke is mechanical.. and it is a 600 cfm... so i can get rid of the oil feed lines and just add it myself..i was reading up on the nikki's and saw the thread on removing the rats nest which he already did. he had the motor rebuilt and couldnt get it to run so he just quit.
Old Apr 13, 2009 | 05:49 PM
DivinDriver's Avatar
1st-Class Engine Janitor
You'd also need a blockoff plate for the metering pump.
Or a bucket to tie to the front of the engine, to catch all the oil.
Old Apr 14, 2009 | 03:19 AM
AKA mrwankel82
I went to the site and I didn't see a spot on buying so I just thought I'd ask. And all I did about the OMP is I just took a small segment of line and hooked the two lines together. I didn't really see a need for doing the whole block plate thing and creating the possibility of having an oil leak there unless you already have it leaking.
Old Apr 14, 2009 | 06:11 AM
Kentetsu's Avatar
http://sterlingmetalworks.com/smw_services.htm
There you go man. They do tend to kick ***...
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
