windshield wiper motor
Old Apr 11, 2009 | 06:06 PM
kevyn_rx7's Avatar
I'm charming
couldn't find any past threads on this, and couldn't find it in the haynes manual...
what plugs into the windshield wiper motor to give it power? i can't for the life of me find a harness to attach to it...
the car is a '90 gxl w/ '91 tII swap
many thanks
Old Apr 11, 2009 | 10:17 PM
RotaryRocket88's Avatar
Top Down, Boost Up
A US-spec engine management harness will have the plug for the wiper motor, but a J-spec harness will not. If the turbo swap was done using the J-spec harness, it's possible the wiper harness will be completely gone.
Old Apr 11, 2009 | 11:02 PM
misterstyx69's Avatar
Retired Moderator, RIP
Ya..+1 on the Wiper wiring being on the Harness.
Can you "maybe' use the original N/A wiring?that would have the Wiper motor harness on it?..
alot of guys run into Snafu's lik ethat when doing swaps such as yours.
I'd be Comparing Harnesses to find out what would be simpler rather than Using the "proper" harness.
(Myself,I am putting a S5 Tii Keg into an S4 N/A using the N/A's Engine harness..Why?Because it is Easier.,NO Farting with extra wires to the alternator.repinning etc).
anyways.I hope that Tid bit of info helps..(see if you can find the Factory service manuals ONLINE.they are Free..).
Old Apr 12, 2009 | 10:06 AM
kevyn_rx7's Avatar
I'm charming
the original harness is all cut up unfortunately. i may be able to squeeze some life out of it though.
anyways, thanks for your help fellas. i may try what you suggested.
Cookboy
1st Gen General Discussion
18
Oct 12, 2015 06:55 AM
Snook
14
Oct 1, 2015 10:56 AM
doritoloco
Sep 5, 2015 12:41 PM
