Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Wolf 3d v4 ref and sync
Old Apr 11, 2009 | 02:37 AM
kepsus's Avatar
Helle everyone, since it is my first post here at the wolf section, Then i would like to say this forum part seems to be the best i have seen about Wolf 3d.
I own a fiat coupe 16vturbo, and have now installed a older Wolf 3D V4 on it, but i have some trouble.
I was going to use ref with sync, i have a 4 point trigger on the crank and one at the cam.. (info here) http://coupeweb.net/16vt/index.html
But if i look at my hard copy manual, then i loot likes both signal should go to pin 28-27 and pin 6 IS onlune if i want to use Coil negavtive.
But if i download the manual from Wolf http://wolfems.com/files/Installatio...457%201004.pdf
Then it say i should use the pin6 as sync ??
The other things seem like i have to use a 1K Ohm, 1/4W pull-up resistor, because it seems that it was build in my old ecu.
Regards
Kenneth
Old Apr 11, 2009 | 05:21 AM
kepsus's Avatar
Another story, have some manage to upgrade the firmware self, ot is it only Wolf who do that..
Old Apr 11, 2009 | 06:24 AM
kepsus's Avatar
here is the file i have used to try to start her.
File Type: wmf
Rbkouki
Dec 9, 2015 08:01 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
immanuel__7
Megasquirt Forum
14
Sep 7, 2015 07:25 PM
Pianoteacherevan
Aug 29, 2015 01:55 PM
