Help~
Old Apr 10, 2009 | 02:17 PM
woxlf's Avatar
TX Help~
Sorry to bother you guys. I have a second gen fc 87 with wiring issues. I need to know what color wires connect to the (L) igniter near the front of the car. The wire's for the signal to fire the coil were cut at some point and I can't figure out which area of the harness to use.
pics to follow.
Old Apr 10, 2009 | 02:30 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Check the FC section under the FAQ, find the link to the FC Wiring Diagram and the colors will be on there. If you cant read a wiring diagram, i will be on later and will look it up.
Old Apr 11, 2009 | 01:51 PM
woxlf's Avatar
TX >.>
I think I found it, it was a white connector at one point, with a green yellow and a black that went to a white two pronged connecter that changed to a red and yellow at the coil. The diagram references a condenser in line with the ground. But I think that it just grounds through the base of the coil. Working on pics.
