Freakin' Windows!
Old May 27, 2002 | 08:07 AM
mwpayne's Avatar
Admitted 'rexaholic'
Freakin' Windows!
Ok, I'm so close to getting the 85 the way I want it, its the small PIA's that I have left, such as, WINDOWS!.
I have lubed the regulators, drilled new holes for the adjustment screws, moved them all around, etc. Still, the windows go fine until they get close to the top, then will not hit the top seal/groove correctly. Almost like the glass is warped! Any ideas? These are the manual windows. Thanks!
Old May 27, 2002 | 08:43 AM
DONNA's Avatar
got mine to do just about the same way, other than buying new rubber , i think were stuck with the little help of the fingers at final roll up, have to apply a little pressure towards the end,,,,sorry.......
Old May 27, 2002 | 09:53 AM
mwpayne's Avatar
I noticed that most new cars (any type) have a plastic do-dad at the top of windows to help guide them in place at the top. Wonder if we could retro-fit something like that? Anyone ever tried it or have another solution? I know these windows didn't do this new, something must have changed with time & wear.
Old May 27, 2002 | 10:12 AM
damon's Avatar
the rubber felt covered sleeves around the window track is old and stiff , it used to be soft and would grip the window and hold it on track . Also , the two plastic strips on the door at the base of the window are more than likely hard and cracked (and very brittle) and these served the same purpose
as for replacement victoria british sells them , but believe it or not the dealer is less expensive about $40 us per door and Im not sure about the track strip
peace
Old May 27, 2002 | 12:48 PM
mwpayne's Avatar
Yep, damon, all you said is true of my rex. This makes sense, I'll start checking on prices for replacements.
Thanks!
Old May 28, 2002 | 12:23 AM
etherhuffer's Avatar
If the rubber won't work, its the window frame. Trust me its true. You have to bend the frame! I freaked the first time I did it. I was dead sure the damn frame would pop off the door. It didn't and now it works. Check those welds first. A Mazda repair shop told me to do this! Very nerve wracking.
Old May 28, 2002 | 11:36 AM
crankit's Avatar
Same problem just ordered 2 new glass run channels from Mazdatrix for $43. each. hope its them they were both shot if not its regulators sloppy.
Old May 28, 2002 | 11:43 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
On top of what everyone else did, including bending the window frame, and making sure the window runner inside the door is straight and setup right, a cheap and easy band-aid fix is to spray some valvoline synthetic lubricatant or silicone spray on the door frame seals. softens them up and lets the window slide up better.
Or if you don't doing it the Manuel way, just ditch the power windows and switch to Manuel windows. I did that and it got rid of one more headache.
BradP
Old May 28, 2002 | 10:17 PM
mwpayne's Avatar
These are manual windows, sorry, I didn't mention that.
Took the regulator out tonight, the center pivot got lots of play. Cleaned, lubed, reinstalled. I noticed if I use my hand to help hold up the forward (left, I'm working on passenger side) side of the window as I roll it up, it goes up perfectly. Pretty sure now its the reg. Probably need to replace channels as well, 'cause if they bind, that wears the reg that much faster. Mazdatrix and Mazda want $105 for regs!!! Back to the boneyards.
'nuther words, replace all but glass! Anyone agree?
Old May 29, 2002 | 09:07 PM
mwpayne's Avatar
*UPDATE* Got two good regulators at the boneyard today, lubed 'em up, windows work like new! Then, got an email from a member offering me good regs, rubber, etc out of an '85.
This seems to fix these sticky manual window problems. Anyone need this stuff, email is MLauralove@aol.com.
Hope this helps someone!
DocHoliday89
Power FC Forum
11
Feb 18, 2018 01:35 AM
turbojeff
Oct 5, 2015 10:50 AM
