Fuel on spark plugs...
Old Apr 5, 2009 | 11:20 AM
fcs3l0ve's Avatar
No Pistons!
Question Fuel on spark plugs...
I own an 86 N/A GXL. The car was running fine the night before and I came out to start it in the morning and it wouldn't start. I took out the spark plugs and theres fuel all over them. I dont understand what could be causing this, is the engine just flooded or is there something leaking? What should I do?
Old Apr 6, 2009 | 10:13 AM
Aaron Cake's Avatar
Engine, Not Motor
First try the unflooding and see what happens. It may just be randomly flooded.
Old Apr 6, 2009 | 12:39 PM
old_skool's Avatar
you know you want this
leaky injectors? did you shut it off last night before it was up to temp?
Old Apr 6, 2009 | 07:48 PM
fcs3l0ve's Avatar
No Pistons!
No, it cant be leaky injectors I just replaced them about 2 weeks ago. I tried replacing the spark plugs and that seemed to work. If it happens again I'm going to try the deflooding procedure and see if that's it.
Old Apr 8, 2009 | 07:03 PM
fcs3l0ve's Avatar
No Pistons!
I dont know the car seems to start after i take the plugs out and clean them off take the egi fuse out and then put it back after cranking it a few times but is there any other thing that can be causing fuel on the spark plugs?
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
alphawolff
Nov 17, 2015 05:57 PM
