85 GSL SE wont start
Old Apr 5, 2009 | 03:04 AM
AntonL's Avatar
Dr. Drift
again after doing stereo work my car wont start. i had it in on so i though it just flooded but when i checks my plugs were all dry, and after trying all of the flooding tricks it still wont start and all the plugs are dry. it ran fine about 2 or 3 hours before and just dies on me... any suggestions? sounds alittle like maybe the fuel pump because its not even trying to start and the plugs are dry. any suggestions? i had just put in a subwoofer if that changes anything.
Old Apr 5, 2009 | 03:16 AM
Romulan_7's Avatar
It isn't trying to start as in it isn't cranking, or it just isn't firing?
Old Apr 5, 2009 | 05:54 AM
Rx-7Doctor's Avatar
Verify you still have spark to the trailing side.
Old Apr 5, 2009 | 11:37 AM
AntonL's Avatar
Dr. Drift
it isnt trying as in its cranking but and turning over but its not firing i guess. im not sure how to explain it.
Old Apr 5, 2009 | 12:36 PM
AntonL's Avatar
Dr. Drift
so i messed with me some more and it seems like a problem with either the injectors or the guel pump/filter. all of the plugs are coming out dry and when they're out the holes are dry and theres no fuel spray. where would i fiind the fuel filter on there and the fuel pump? can someone post a picture?
Old Apr 9, 2009 | 11:20 PM
phoenixburning's Avatar
roadkill
the fuel pump and filter are under the car behind the the drivers door. I would check the wires to the pump. you said you installed a woofer when it happened, if you put it in the trunk. that is where the wires to the pump are and you may have damaged them.
Old Apr 10, 2009 | 10:04 AM
74RX4's Avatar
Round and Round
Not really the trunk, but under the left side storage bin. The wires run to a plug then out through a hole in the floor. Find the fuel pump test plug at the rear of the air filter box. It is an empty two terminal white plug with a black rubber cover. Connect the two terminals together and your fuel pump should get power when the ignition switch is turned on. You can then check for power at the plug under the storage bin.
Old Apr 10, 2009 | 02:32 PM
AntonL's Avatar
Dr. Drift
yeah i checked it out and it was just the power cable to the fuel pump, stupid mistake haha, thanks for all the advice everyone, very much appreciated
The1Sun
Mar 18, 2018 11:08 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
