Weird gas leak...
Old May 26, 2002 | 07:48 PM
MILD7's Avatar
Question Weird gas leak...
Interesting problem developed last night. Started up my mildly modded '94 after sitting all day. Noticed a pool of liquid forming in the gutter. Low and behold, gasoline! And it appeared to be dripping from somewhere near the oil pan. Well, here's the weird part. Drove it home, jacked it up, and let the car sit or awhile. No gasoline. Started it up... and no leak as well. When I crawl under the car, it smells like gas around the oil pan, put I cannot seem to locate an obvious leak. I let the car sit over night, and still no leak. Started the car cold, and no leak (I let it idle for a good 5min.
By the way, I have not touched the fuel system, except for replacing the fuel filter about 20K miles ago. The engine has 129,000 miles on it. Mods are efini y-pipe, down pipe, exhaust, intake,and greddy pulley.
Any insight would be greatly appreciated!!!!
B.
Old May 26, 2002 | 08:52 PM
mightyslash's Avatar
Will Work for Ferrari
Damn dude, you should get an ECU or upgrade the fuel system. Not to mention your engine has 129k miles.
Old May 26, 2002 | 08:56 PM
MILD7's Avatar
HAHA.. I know, I know... but engine already needs replacing due to coolant seal failure. And I'm only boosting .7 bar anyways. I doubt I'll blow an apex seal.... something else will surely go.. heh heh.
Old May 26, 2002 | 09:03 PM
Yeah, either way you need to rebuild it. Just make sure you dont drive with a fuel leak.
Old May 26, 2002 | 09:05 PM
MILD7's Avatar
I know.... KABOOOM!!! That's why I'm currently trying to figure it out... and I'm baffled. By the way... how difficult is it to drop in a Mazda reman. yourself? I have some experience around rotaries... but not a whole lot.
Old May 26, 2002 | 09:09 PM
Shops charge $1-1.5k just to take the old one out and install a new one. So, you can imagine the amount of work and labor if you do it youself.
Old May 26, 2002 | 09:11 PM
MILD7's Avatar
yeah... I heard about that... and that's if nothing else needs replacing. I heard the downtime is long as well. Which sux,since this is my only car. I am pressing my luck..and pretty soon, I'll be S@*% out of luck.
Old May 26, 2002 | 09:13 PM
Well, if your mechanic is fast, it will be done in 1-2 weeks.
Old May 27, 2002 | 12:11 AM
weaklink's Avatar
Resident Retard
what about the fuel pulsation damper?
Old May 27, 2002 | 12:13 AM
MILD7's Avatar
you know, I've heard of it before, but quite honestly, I have no idea what it does or where it's located. Can you point me in the right direction? Thanks!
Old May 27, 2002 | 12:15 AM
Probably not the pulsation dampener. He said there's a pool of gasoline dripping near the oil pan.
Old May 27, 2002 | 12:16 AM
Do you smell fuel when you pop the hood
Old May 27, 2002 | 12:20 AM
MILD7's Avatar
the funny thing is that sometimes I do smell gas under the hood, and sometimes even inside the cab of the car. But it's not that often. It's like it comes and goes. Very strange. The few occasions I did smell a trace of gasoline was usually at start up with engine cold.
Old May 27, 2002 | 12:23 AM
Yeah, sounds like you have a fuel leak. It's either the PD or the o rings on the injectors. But it shouldnt be dripping like hell.
Old May 27, 2002 | 12:25 AM
MILD7's Avatar
Am I correct by assuming that both these items are fairly difficult to get to? Was wondering if I should jump into DIY or whether I should just drop it off at the mechanic.
weaklink's Avatar
Resident Retard
mechanic, and hurry...
Old May 27, 2002 | 12:27 AM
weaklink's Avatar
Resident Retard
https://www.rx7club.com/forum/showth...sation+damp%2A
Old May 27, 2002 | 12:28 AM
weaklink's Avatar
Resident Retard
Old May 27, 2002 | 12:29 AM
You have to take the intake manifold, throttle body and solenoids (those stuff on top of the engine) apart in order to get to the PD and injectors. It's a pretty intensive job.
Old May 27, 2002 | 12:30 AM
weaklink's Avatar
Resident Retard
one more
Old May 27, 2002 | 01:41 AM
MILD7's Avatar
Hey weaklink and mightyslash, thanks for all your input and taking the time and effort to respond. You knowlege if very helpful! Peace!
Old May 27, 2002 | 02:37 AM
rotorbrain's Avatar
fart on a friends head!!!
if youre changing your fpd take the acv off. it is easier to access the pri. injectors and the fpd and the vaccum hoses for that matter. if you have the money i would go ahead and get it rebuilt with everything you need and want. thats the easy/expensive way. haha.
Old May 27, 2002 | 12:13 PM
7-sins's Avatar
thats not paint....
My pulsation dampener was leaking.... I didn't think much of the gas smell until I saw a puddle of fuel underneath my car. After that I pulled of my intake manifold only to see probably a 3-4" deep pocket of fuel on the block. Either way injectors/fpd you are going to be working in the same spot, just start pulling the manifold off and check for a fuel puddle.
Old May 27, 2002 | 06:57 PM
djantlive's Avatar
Definitely take it to a rotary shop to have it looked at. Dont wait or you'll be joining the folks with tragic hood BBQ. It's $500 or so to fix the FPD or the injector. It could be a gas line too. Call mazda with your VIN to see if the fuel line recall was done on your car.
Old May 27, 2002 | 07:52 PM
7-sins's Avatar
thats not paint....
Wow $500, that is some money. I'm happy I did the work myself, even though it was a PITA.
