Haltech New to Haltech, Have a Map, Needs Checking Over
Old Apr 4, 2009 | 02:57 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Hi there everyone,
I am a Power FC and Datalogit kinda man.
But I am helping my friend get his FD finished up, he bought it half completed.
Here is the setup
13B REW
550 Pri 1600 Sec
Stock FD CAS
Stock Coils
3 Bar GM Map
Stock TPS
Stock Air Temp
Stock Water Temp
Stock Twins Non-Seq
I have everything powered up and it seems to see a rpm signal when you turn the engine over but I am not getting any spark, it has power to the coils, so I think it is either wiring or the setup on the Haltech
I have pulled the Map off of the E6X and will attach it to this thread. I am changing the file ending from its .6xm to a .txt, so all you have to do is change it back to .6xm
Will you look it over and see if this is a base map that would start the car. Is there anything that would cause the no spark issue.
I only checked the Leading, there isnt anything that causes it not to spark at lower RPM.
Just let me know, Thanks.
File Type: txt
Old Apr 24, 2009 | 10:37 AM
vh_supra26's Avatar
I
I miss my car , someone please help
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
rotor_veux
Sep 3, 2015 07:10 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
