West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Help with A/C?
Old Apr 2, 2009 | 12:23 AM
Marck's Avatar
Help with A/C?
Where can i depressurize my A/C so i can take off my Air conditioning system? Sorry if its a noobish question still kinda learning my car THANKS!
Old Apr 2, 2009 | 01:31 AM
SINxSELEKTAH's Avatar
Punkrockin JUNGLIST
get yourself a pair of welding gloves and a screwdriver. stick it in the low pressure side, press the schrader valve, and bam! your A/C is good. just don't let anybody see you do it, especially those tree huggers
Old Apr 2, 2009 | 02:16 AM
iLikeEatPoo's Avatar
The Great Dick
Hammer and a good pair of strong arms then rip it off. If you can't find a pair of strong arms check autozone they usually carry it.
Or do away with it all with a sledge hammer.
Old Apr 2, 2009 | 03:19 AM
Apex944's Avatar
Technician
You can also do the welding gloves and a schrader valve removal tool on either the low or high side.
Just unscrew one of the schrader valves and let it vent, just try to avoid breathing it in as it's not all that great for you...
It may have a good amount of pressure behind it so when you nearly have it out it may shoot out quite fast so be careful.
And yes, don't let people see you vent it haha. I cant remember exactly for just one person if you'll get in trouble, but I know for sure that if you do it in a shop it's a hefty fine.
Old Apr 2, 2009 | 01:25 PM
Marck's Avatar
So as soon as i stick the screw driver on the low pressure side (where you fill it with the charging kits?) Then its safe to remove the whole ac system?
Old Apr 2, 2009 | 01:53 PM
The Great Dick
just rip it out if your going to remove it. if you want to recharge it guess who you got to call.
Old Apr 2, 2009 | 02:50 PM
Punkrockin JUNGLIST
correct, just make sure all the R134a or R12 (if yours hasn't been retrofitted yet) has completely escaped from the system.
DO NOT LET OTHER PEOPLE SEE YOU DOING THIS
or if you have money, take it to any service station with a licensed HVAC technician
Old Apr 2, 2009 | 05:37 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Be carefullllll
WARNING!!!!!!!!!!!!!
R134 IS CARCIOGENIC (known to cause cancer). Could be a Class 1 issue.
You do not want to just vent R134 for serious health reasons. That needs to be done in a closed loop maner.
R12, not so much.
Old Apr 2, 2009 | 06:03 PM
Punkrockin JUNGLIST
orly? what about R134a?
Old Apr 3, 2009 | 11:42 AM
HOZZMANRX7's Avatar
Thumbs down
Laughing at cancer.
Old Apr 3, 2009 | 12:31 PM
DivinDriver's Avatar
1st-Class Engine Janitor
R12's not toxic (unless you're an ozone layer, supposedly), but you don't want to expose it to a flame. Converts it to an effective nerve toxin.
Old Apr 3, 2009 | 01:13 PM
Marck's Avatar
So you want me to like wear a gas mask haha or what can i use to cover my face so i can breathe properly
Old Apr 3, 2009 | 02:30 PM
Punkrockin JUNGLIST
Originally Posted by HOZZMANRX7
Laughing at cancer.
there's a difference between R134 and R134a.
Old Apr 3, 2009 | 06:20 PM
HOZZMANRX7's Avatar
True, but it the fact I didn't type the "a" doesn't take the issue away from the IP.
More to the point, if you're needing to vacate a R134a AC system, you need to have it done with a closed loop machine. Any AC shop is set up to do this for you. I used Walnut Auto Air on Valley in Walnut (near Fairway)
Coochas
44
Nov 5, 2019 11:08 PM
Turblown
Sep 30, 2015 05:58 PM
