dieing problem
Old Apr 1, 2009 | 02:06 PM
jd89's Avatar
dieing problem
ok so, ill be driving my carand under full throttle it will do fine but its when i come to a stop that it will die, no idle just dies, i have a weber siddraft set up, 45dcoe jets are f 11, 220, with a 300 main, i dont know if its a fuel promblem or what so help would be great thanks, mods: rb header and exhaust holley blue, weber side draft, msd ign, clutch and flywheel
Josh
Old Apr 1, 2009 | 05:14 PM
jd89's Avatar
i need help guys i need this ready for the track saturday
Old Apr 1, 2009 | 07:44 PM
blackdeath647's Avatar
weak minds wear the crown
sounds to me like it may be a vacuum leak. raise the rpm just to get it to idle so that you can find where the leak is by spraying some carb cleaner.
Old Apr 1, 2009 | 09:00 PM
JoeyMazda's Avatar
"81 RX-7
Doesn't the shutter valve control the rpm's when they come down? I had a similar problem & thought it was a vaccuum leak. Couldn't find a vaccuum leak.. replaced the shutter valve & fixed the problem.
Old Apr 2, 2009 | 12:38 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Good tip. I'll bet that's not in the Weber manual.
Old Apr 3, 2009 | 09:36 AM
jd89's Avatar
ok wheres the shutter valve located? i looked for vaccum leaks all day yesterday and didnt fiand anything, went through lik 3 cans of choke cleaner lol
Old Apr 3, 2009 | 10:56 AM
DivinDriver's Avatar
1st-Class Engine Janitor
Would a Weber setup even still have a shutter valve?
Wouldn't it have gone away with the manifold swap?
Old Apr 3, 2009 | 12:16 PM
jd89's Avatar
thats what i thought i just looked everywhere for it and couldnt find it
jd89's Avatar
i think i might have a fuel pump problem
Old Apr 3, 2009 | 12:18 PM
jd89's Avatar
ok so heres the deal theres a valve on the intake side of the carb, if i hold it in the middle it will idle but idle high, and it runs like total **** if i drive when its open
Old Apr 3, 2009 | 12:20 PM
Pix?
Old Apr 4, 2009 | 04:24 PM
jd89's Avatar
ok so i cleaned my jets and it idles fine, now i cant even be under 1/4 throttle and it starts to bog
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
R.O.D
34
Jan 6, 2016 12:09 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
