Speedometer wrong reading
Old Apr 1, 2009 | 07:25 AM
zaltec's Avatar
Hi all,
i noticed that my FD speedometer is off by 12 km/h at 140 km/h (reading 140 km/h when accurate gps speed is 128 km/h), which is a 8.5% error, really too much.
Is there a way to fix it and reduce this error to 2-3%?
Best Regards,
Giorgio
Old Apr 1, 2009 | 09:14 AM
Icemark's Avatar
do you have a non-stock sized tire and or wheel on the car?
Old Apr 1, 2009 | 11:45 AM
dgeesaman's Avatar
Might you also have a non-standard rear drive ratio? (Automatics are 3.90, manuals are 4.10, and in the JDM market I think there are some 4.33's floating about)
As well, if you have 100% stock drive ratio and tire size, have a look at whether the speedo sensor might be changed by accident. There is a different speedo sensor for each final drive ratio.
Old Apr 1, 2009 | 03:04 PM
zaltec's Avatar
Car is stock for what i know. Maybe i can take a look at the speedo sensor tomorrow
Old Apr 1, 2009 | 04:15 PM
dgeesaman's Avatar
What tire size?
Old Apr 1, 2009 | 05:07 PM
zaltec's Avatar
225/50ZR16, it's stock
Old Apr 3, 2009 | 04:05 PM
LoTim's Avatar
Twin Turbo Terror
your limited slip or non limited slip diff its whats causing this
Old Apr 4, 2009 | 11:10 AM
zaltec's Avatar
Hi LoTim,
what do you mean?
LSD is broken? Maybe a fluid change will solve?
Old Apr 4, 2009 | 12:21 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Originally Posted by zaltec
Hi LoTim,
what do you mean?
No, that's completely unrelated.
This is a tire size / speedometer gear / rear end ratio problem.
Old Apr 6, 2009 | 03:06 AM
zaltec's Avatar
Is there a way to check the rear end ratio?
24seven_dada
20
Nov 10, 2018 12:03 PM
