S4 TII Rotor Housings On S5 TII Motor
Old Mar 30, 2009 | 01:56 AM
My90Turbo's Avatar
Hi, i bought two S4 TII rotor housings from a guy to use in my S5 TII motor. Has anyone successively ran S4 TII housings on a S5 turbo motor? If so what else do i need to change to make it work? I'm going to be running a redom ECU with a fuel controller. Any help would be great. Thanks
Daniel
Old Mar 30, 2009 | 09:44 AM
Aaron Cake's Avatar
Engine, Not Motor
Should be fine but be aware the spark plugs are in a slightly different location and since the emissions passages don't line up, you won't be passing emissions.
Old Mar 30, 2009 | 12:19 PM
My90Turbo's Avatar
Ok, smogs not a problem. But i was told that i have to run the S4 pulley that has the timing marks on it because of the slight timing difference.
Old Apr 2, 2009 | 01:24 PM
Aaron Cake's Avatar
Engine, Not Motor
If all you are swapping is rotor housings, then leave the pulley alone. Use the pulley and hub combination that came with the car.
Ciclovnz
Oct 18, 2015 03:04 PM
cdn
14
Sep 10, 2015 06:23 AM
Brice_Brice
Aug 18, 2015 10:42 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
