Four to Five Lug
Old Mar 29, 2009 | 04:01 PM
JaredCarpenter's Avatar
Four to Five Lug
Is the stock s5 suspension and five lug hub assembly interchangeable with a n/a s4 four lug?
Old Apr 4, 2009 | 05:13 AM
SilentNight1647's Avatar
It's pretty much a bolt up deal, the only thing is you want the whole rear carrier it keeps you from pressing it apart which is a pain if you don't have the appropriate tools.
Old Apr 9, 2009 | 12:49 PM
wrcRS's Avatar
I just finished this swap, you will need the entire rear knuckle like SilentNight says. You will need the rotors front and back, front hub assembly with bearings and pads front and back. I upgraded the brake lines to S.S. braided. Other than that, its a pretty easy swap done in a day.
Old Apr 10, 2009 | 11:20 AM
The suspension is the same way?
Old Apr 13, 2009 | 01:59 AM
wrcRS's Avatar
Im not sure I understand your question, but yes, the shocks and struts are the same.
Another thing, you will need the calipers as well front and back.
Old Apr 13, 2009 | 03:05 AM
daragez's Avatar
i don't think so.....lol
