Sunroof working???
Old Mar 28, 2009 | 04:30 AM
Ohhface's Avatar
Sunroof working???
I have a a problem with my sunroof when i press the open button you can hear the motor sounds a bit weak but nothing happens... I dont know anything about sunroofs either so any help would be nice. I dont know how to look in side cause the cloth doesnt slide back and this is my 1st car i have ownd with a sunroof. any input would be great
Old Mar 28, 2009 | 01:05 PM
sa.rx7's Avatar
9o fc bone stock s4
yea man same here i just bought my fc
Old Mar 28, 2009 | 01:10 PM
sa.rx7's Avatar
9o fc bone stock s4
yea man same here i just bought mi fc and the same thing happens.but try cleaning the tracks to do this first have to open the sunroof . i did this by preesing the buton and then by helping the sunroof open by pressinf against it from the part of the sunroof that is located towards the back of the car.(while pressing the buton you have to help it open by giving it a push. hope this helps
Old Mar 28, 2009 | 06:26 PM
sa.rx7's Avatar
9o fc bone stock s4
Hey its me again,i looked into the owners manual and the haynes book and if you have the second gen(fc) then there should be a manual override right behind the sunroof there is a little plug that you take out to open it manually ,you need some sort of tool though.
Old Mar 29, 2009 | 04:01 PM
trochoid's Avatar
Old Fart Young at Heart
The tracks for the FC sunroofs need cleaned and lubed occasionaly. Continually operating a sticking one will break the drive mechanism. Download the FSM from the following link and make the needed repair.
http://foxed.ca/foxed/index.php?page=rx7manual
Old Mar 29, 2009 | 04:26 PM
13bturbofc's Avatar
mmm doritos
here is a good write up for ya. doing this will fix it 75% of the time..http://howto.globalvicinity.com/gv_w...=288&co=1&vi=1
Old Mar 31, 2009 | 11:08 PM
Ohhface's Avatar
Cool i checked out both that write up seems well thought out i will have to try it tomorrow and see how it works out
Thanks!
Old Mar 31, 2009 | 11:36 PM
sa.rx7's Avatar
9o fc bone stock s4
Hey man and if that doesnt work you can always go to the junkyard like i did and get a motor that works for cheap. I picked one up for 5 bucks.
Old Apr 3, 2009 | 10:16 AM
RJRX-7's Avatar
I have to push up the sunroof to when i want to use it, but will lubricating the tracks make it so i won't have to push it anymore? it's not much of an inconvenience, just curious to see if it works
Old Apr 4, 2009 | 03:37 PM
Rot8n87's Avatar
I tried pushing up while pressing button and I heard a crack. Now my sunroof stuck maybe 1/8th open. The drivers side is more open than the passenger side. I have no clue what to do from here. My car is going to get flooded when it rains. Doh.
Old Apr 4, 2009 | 04:46 PM
sa.rx7's Avatar
9o fc bone stock s4
No ptoblem theres an overide skrew thing thats right be hind the sunroof. It has a little cover that you take out then find something to place inside and start to unskrew or skrew the little **** thing.but u can always check the manual(car manual) and it should have the sunroof thing mines is a bluish color and its on page 3-60 it tells u how to manual override the sunroof.
Old Apr 5, 2009 | 07:56 PM
JustinsFDpoweredFC's Avatar
Drift Ready FC
This is an excellent post on how to repair your sunroof. Has pictures and everything. Good looking out.
Old Apr 6, 2009 | 06:21 PM
Rot8n87's Avatar
The little over ride hex bolt on my just clicks when i turn it. i think its safe to say my sunroof is fucked.
