rpm bounce whats the deal
Old Mar 25, 2009 | 02:17 PM
slideways0184's Avatar
OK rpm bounce whats the deal
i have a fd with literaly almost ever bolt on you can get for it other then a turbo upgrade which is in the works. when the car idles it rev bounces about 300 to 500 rpms however when i turn the lights on it idles fine anyone have a idea what might be wrong?
Old Mar 26, 2009 | 04:09 PM
dgeesaman's Avatar
Well you can start with an idle adjustment. The procedure is in the 3rd gen faq.
If that doesn't solve it, you might need a new electrical load sensor. I don't know a lot about it except that it matches your symptoms.
Dave
Old Mar 26, 2009 | 04:22 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
your base idle is set too high
or you have a vacuum leak
or your TPS is misadjusted
Old Mar 26, 2009 | 04:47 PM
Skaterking's Avatar
I like them top down
Sounds like TPS
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
jsesq
27
Sep 25, 2015 11:10 AM
The1Sun
Sep 18, 2015 07:13 PM
Im faster
Sep 10, 2015 04:38 AM
