Blown?????
Old Mar 23, 2009 | 09:34 PM
FC<3's Avatar
Blown?????
I'm new to the rotary business, so I need help on this one really bad....
I recently picked up an FC, the problem is the car smokes way too much than I think it should....
it's a rebuild 13b wich I think was rebuild(don't know how long ago)
I'd appreciate if u guys check it out and suggest what's wrong
http://youtube.com/watch?v=_V0CarBMQIY
Old Mar 24, 2009 | 12:13 PM
farberio's Avatar
NASA-MW ST4
Do a compression test on the motor.
Old Mar 25, 2009 | 12:37 AM
trochoid's Avatar
Old Fart Young at Heart
Doesn't sound good, smoking isn't bad, but then you're in CA, so that may be a problem passing emissions. If one rotor only has 2 good comp readings instead of 3, run a can of Seafoam though though it with only 1/4 tank of fuel. Check for exhaust leaks too.
Old Mar 25, 2009 | 09:30 AM
Aaron Cake's Avatar
Engine, Not Motor
That isn't sounding very good, but it may just be the cheapish exhaust.
See http://www.aaroncake.net/rx-7/blown.htm for instructions on how to quickly determine if the engine is dead.
Old Mar 25, 2009 | 01:49 PM
Kentetsu's Avatar
Can't see the video right now, but I'll check later. If the motor is smoking continously, then you might try replacing a quart of oil with Lucas Heavy Duty Oil Stabilizer and see if that has any effect. Blown oil control rings really seem to like the Lucas...
Old Mar 25, 2009 | 02:47 PM
slideways0184's Avatar
OK is this a turbo 7
is your 7 turbo or na
Old Mar 25, 2009 | 06:07 PM
FC<3's Avatar
NA
tnx for the help
7upra
Mar 25, 2018 11:32 AM
BLK 93
Sep 28, 2015 01:45 PM
