$150
Old May 25, 2002 | 08:19 PM
Wattz's Avatar
$150
Is there any worthwhile mod that I could buy for $150 that wouldn't require me to buy anything else?
I'm hoping you guys know of a HP-improving mod, but if not then just throw out whatever comes to mind.
Old May 25, 2002 | 08:45 PM
WackyRotary's Avatar
standard combustion
Headers sounds like that price range about
Old May 25, 2002 | 08:49 PM
would you get much of a HP increase if you put on headers and didn't do the rest of the exaust system?
Old May 25, 2002 | 10:07 PM
standard combustion
WEll, I guess I should of said, headers & straght pipe back to the muffler. I would throw in a pre-silencer or glasspak in there to keep the exhuast note pleasent. Maybe make your 2ndaries mechanical. It will feel more responsive but also lose more gas. he he.
Old May 25, 2002 | 10:12 PM
Kill No Cone's Avatar
Save your money and desigh a process to create the car you want. Throwing money at a car rarely makes any sense.
Old May 26, 2002 | 12:32 AM
V8kilr's Avatar
for $150.00 i would try to do all the "cheap" freebie mods
thats the most bang for the buck,
sterling's carb mod
poor mans direct fire
cheap straight pipe to bypass the three cats
cut up the air box or go custom ram air
remove emissions equipment
you will get more from these then any single $150.00 mod
i know because i have well over $2,000.00 in performance parts and i already did all the mods above first,
you have to start somewhere
Old May 26, 2002 | 12:43 AM
adssoccer's Avatar
k&n cone for a 13b (~$75 ish)
exhaust
Old May 26, 2002 | 12:46 AM
V8kilr's Avatar
exhaust
his profile says 1985 gsl "12a"
Old May 26, 2002 | 07:16 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Get that header!!! Or save yer pennies till ya can get one.
Don't do anything half assed. Non of the mods mentioned so far will have a profound effect on performance (cept maybe the header).
But do all of them, and NOW yer getting somewhere!
Old May 26, 2002 | 11:35 AM
Wattz's Avatar
Hm... I might just save it for a while, or spend it on something else.
I just wanna know why a Holley Carb costs like $800 from RB.
That's just crazy. I could buy 4 parts cars for that. `,=o/
Old May 27, 2002 | 11:23 AM
jeremy's Avatar
male stripper
exhaust is the most restrictive part. most of what dave mentioned is free. time and patience there. if anything save a little more and buy the header and presilencer.
Old May 27, 2002 | 12:39 PM
rxseven's Avatar
Special Dark
Forget about intake or ignition. Use the $150 to get the Bonez race pipe from rx7.com. It is basically a straight pipe with a presilencer, replaces all the cats and bolts to the exhaust manifold. Buying just the headers will only make your car louder and nothing else if you don't do anything downstream. This will be the only $150 mod which will make a noticeable power difference.
Old May 27, 2002 | 02:38 PM
4ohfour's Avatar
How do you create a custom ram air application for a 12a NA?????
I ask because I am very interested....
cheers'
Old May 27, 2002 | 06:22 PM
adssoccer's Avatar
could this bolt straight to a racing beat header?
Old May 27, 2002 | 09:34 PM
rxseven's Avatar
Special Dark
No you will have to modify it, if you want it to bolt to a RB header.
Old May 28, 2002 | 01:52 AM
RotorMotorDriver's Avatar
Seven Is Coming
RB sells a cat replacemet pipe too.
~T.J.
Old May 28, 2002 | 10:50 PM
Don't buy the intake until you have done the whole exhaust system. If you do, I bet you will be very displeased. The exhaust has to come first, the intake will just try to put more air and fuel down a tiny, restrictive exhaust pipe.
Old May 29, 2002 | 02:32 AM
theNeanderthol's Avatar
the torquinator
Well I started my mods with only a header into the stock exhaust it made a huge difference in power! Now I replaced the last cat with a glasspack (very nice)
