air pump hose to ACV
Old May 25, 2002 | 03:08 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I just removed my airpump for the TID mod but I'm leaving the ACV on atleast for a while. too lazy to order a block off plate and remove it.
right now that hose is sucking air into the AVC I think at idle. it's pretty loud. should I leave it or plug it? should it be sucking ??...
Old May 25, 2002 | 09:47 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Mine's still sucking do I cap it or stick a filter on it? what is it sucking for?
Old May 25, 2002 | 11:09 PM
seventhgear's Avatar
boost on the way(GTU II)
filter it u never know what itll suck in
Old May 26, 2002 | 01:46 AM
Scott 89t2's Avatar
SOLD THE RX-7!
dam where is hailers when you need him
Old May 26, 2002 | 05:27 AM
HAILERS's Avatar
HAILERS
If you had a n/a, I'd say take the BLUE connector off the relief solenoid on the drivers side of the engine. BUT if you have a turbo that won't work because of the differences in the acv's. On the turbo try taking the grey or Switching solenoid valves connector off and see if the flow stops at the inlet to the acv(where the airpump hose was). If that does not stop it go with the small air filter that can be had at PepBoys and put it on the acv inlet. If it still leaked after the switching solenoid had its plug taken off(grey) then I suppose the leaking is thru the aav in the acv. That causes fresh air to be sucked into the intake during rapid deceleration. I've seen those small air filters at PepBoys but never bought one before so I've no idea how hard it is to fit one. Jpg attached:
Old May 26, 2002 | 06:41 AM
HAILERS's Avatar
HAILERS
I just thought about this some more. If your acv is an old one, I would bet money the switching diaphram is toast inside it. To prove so, look at the acv. On top it has one hose sticking straight out going to your boost sensor. Just to the left of that one, is a hose sticking straight up. Put a piece of spare vac hose on that NIPPLE and suck. Do you pull a vacuum???? It holds when you put your tongue over the end of the hose???/ Just suck air???/ Just sucking air means the diaphram is toast, as in SHOT, NG, ETC. That would mean that in my first post where I suggested pulling the grey connector off over on the drivers side of the engine, will not work because the switching diaphram is brittle and cracked from the heat. You can replace that diaphram at some later date with a diaphram from some older acv from a 82 or so model car, but a small amount of metal filing is required. About five minutes worth of filing.
Old May 26, 2002 | 08:21 AM
NZConvertible's Avatar
I'm a boost creep...
Re: air pump hose to ACV
Originally posted by Scott 89t2
...I'm leaving the ACV on atleast for a while. too lazy to order a block off plate and remove it.
Rip it off and blank it ya lazy bastard!
Old May 26, 2002 | 08:47 AM
Felix Wankel's Avatar
Super Newbie
Is having no airpump going to **** over your new cat?
Old May 26, 2002 | 08:59 AM
HAILERS's Avatar
HAILERS
I'd still check to see if you can pull a vacuum on the nipple for the switching diaphram in the acv. Might be useful if you ever have to get an emissions check and don't pass. If nothing else, just put a wooden dowel in the hose going to the acv. Same as blocking it off and easier.
Old May 26, 2002 | 11:26 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I passed emmissions yesterday pretty good before I started ripping everything off . so it's probably ok. I'll check the vacuum stuff later. gota work this morning.
I'm pretty sure having no airpump will make the cat last longer. the air from the air pump is what heats the cat cause it causes the burning in the cat.
Old May 26, 2002 | 02:17 PM
gtrr4's Avatar
I have a 91 n/a and just removed the belt off the air pump. I read in a thread somewhere that the back pressure tube off the presilencer (which I have) opened the auxilory ports. So I wanted to see what happend. seemed like I had less acceleration between 7k-8.5k. Also noticed the car does not backfire anymore. Any pros or cons on this? Thanks Jason
Old May 26, 2002 | 03:07 PM
Scott 89t2's Avatar
SOLD THE RX-7!
on the 89-91 N/A's you need the airpump to open the 5/6 ports. ya yeah you just lost 15hp or so from 5000-8000
Old May 26, 2002 | 04:05 PM
gtrr4's Avatar
Thats what IVe been told, but I have also read that the back pressure tub from the presilencer is suppose to do that. I have also seen folks say that they have taken off there air pumps on there series V motors? I am going to put the belt back on, but why are there two variations of this story here?
Old May 26, 2002 | 04:18 PM
Originally posted by gtrr4
...why are there two variations of this story here?
Because there are two different cars. S4's use exhaust backpressure to open the aux ports, S5's use the air pump.
Old May 26, 2002 | 04:19 PM
Scott 89t2's Avatar
SOLD THE RX-7!
well there are 4 kinds. and 2 of them don't have 6 ports so it doesn't matter
Old May 26, 2002 | 05:03 PM
Picky, picky, picky...
Old May 27, 2002 | 09:04 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Re: Re: air pump hose to ACV
ok just ordered the block off plate from www.k2rd.com even us lazy bastards can handle a click click paypal shoping cart
it looks like it's going to lots of fun getting if off with ABS...
Old May 27, 2002 | 09:06 PM
Super Newbie
Re: Re: Re: air pump hose to ACV
I ripped the hell out of my knuckles taking mine off. ******* ABS box has to be right in the way
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
