s4 na swap to a turbo
Old Mar 16, 2009 | 01:50 AM
blowinslidewayz's Avatar
always slidewayz
i have a 86 rex and wanted to know everything involved in doin a turbo swap... like trannies drivetrain the whole nine yards that would havta be changed...and could i build up a na block to a turbo block since i have an extra laying around....thanks
Old Mar 16, 2009 | 08:55 PM
farberio's Avatar
NASA-MW ST4
You need to do a lot of research.
The easiest thing to do is to swap in a turbo motor of the same series.
You don't have to change the whole drivetrain, but its a very very very very very very good thing to do.
If you search around for turbo swap its been covered many times.
As far as turboing your n/a, everything has to be custom fabricated. If you have the skills and the knowhow it may be a good idea, if you don't then stick to a turbo swap.
Old Mar 17, 2009 | 03:04 PM
Aaron Cake's Avatar
Engine, Not Motor
Just take a look at the 2nd gen FAQ sticky. Since this question is asked 1.7 million times a day, it is well covered in the FAQ.
Old Mar 18, 2009 | 10:41 PM
always slidewayz
ok i have a tranny as well the kid said its a turbo tranny bbut im not sure ho can i find out plus can i just build that tranny to handle what i wana do which is ashieve four hundred horsepower unles thats unrealist lol
Old Mar 20, 2009 | 10:40 AM
Aaron Cake's Avatar
Engine, Not Motor
The turbo transmission has a large inspection plate on the bottom. The NA transmission doesn't and just has a drain plug.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
Machupicchu
Aug 17, 2015 08:27 PM
