1988 starter problems
Old Mar 15, 2009 | 07:52 PM
BIGGUY4614's Avatar
Went to start car this morning, starter just spun, replaced with a new one, it's doing the same thing, it's not turning over just spinning..????
Old Mar 16, 2009 | 09:08 PM
farberio's Avatar
NASA-MW ST4
Are you positive the motor is not spinning?
If it feels like low compression the motor is probably flooded.
Old Mar 16, 2009 | 10:03 PM
Kentetsu's Avatar
Good call. Have someone watch to see if the belts are turning while trying to start. If they are, then you are probably flooded which makes the motor spin very freely and can sound like all kinds of weird ****. If this is the case, then pull out both top plugs, and inject an ounce or so of Seafoam into each of the holes. A turkey baster is great for this, and can be found at the grocery store for a couple of bucks.
Seafoam will usually start a flooded rotary in no time, clean the apex seals, clean the spark plugs, and make your car capable of walking on water all in one shot. No ****, the stuff is really that good....
Monsterbox
Sep 11, 2015 03:29 PM
Enzo1944
Sep 6, 2015 08:57 AM
