new starter?
Old Mar 12, 2009 | 08:52 PM
calicos's Avatar
wett
CA new starter?
so i went to start my fd today and when i turned the key nothing happened. im guessing its the starter. how much will it cost me to get a new one?
Old Mar 13, 2009 | 10:45 AM
Icemark's Avatar
Or you have a dead battery.
Do the headlights AND horn work? If they don't or are weak, you probably have a bad battery or bad battery connections.
Old Mar 14, 2009 | 04:40 PM
calicos's Avatar
wett
my headlights work, power fc works, stereo works, and turbo timer works. so im guessing its the starter. im gonna have to bump start the car to find out i guess. am i right?
Old Mar 14, 2009 | 05:13 PM
jasperman's Avatar
Murphys' Law
have you checked the connections between the battery and starter(just a suggestion)
Old Mar 14, 2009 | 06:20 PM
calicos's Avatar
wett
i have to look more into that. that might be the problem
Old Mar 14, 2009 | 09:21 PM
hanman's Avatar
Try standing in front of the car with the headlights on, and have someone try and start the car. If the headlights dim way down, it's probably a battery issue. If they don't dim at all, it's probably a starter issue. If it's the starter, try rapping it pretty good with a hammer. If it works, you need a new starter.
Old Mar 15, 2009 | 07:44 PM
BIGGUY4614's Avatar
My rex's starter spins but is not engaged to turn it over, i replaced starters and the new one is doing the same thing????
LongDuck
Oct 7, 2015 08:12 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
Devon Murray
Sep 25, 2015 09:41 AM
