wont start anymore....:(
Old Mar 6, 2009 | 02:13 PM
SidoDorifto's Avatar
Unhappy wont start anymore....:(
FC 87 non turbo.....did the motor swap and it was successful car started..drove it around for a few days then noticed that one of the primary injectors was leaking...so what i did is i changed all the O rings on the injectors once i put everything back on the car didnt want to start......i tried the unflooding procedure but it still didnt start.....checked one of the leading spark cables to see if it was giving spark and it didnt....what happened anybody have any ideas please help
Old Mar 7, 2009 | 12:52 PM
farberio's Avatar
NASA-MW ST4
Pull the leading plugs and deflood to remove all fuel. Then try starting with a completely charged battery.
Old Mar 8, 2009 | 03:08 AM
trochoid's Avatar
Old Fart Young at Heart
Go back over all of your connections, vacuum and electrical. If you don't have a copy of the FSM, follow the link to the online ones.
http://foxed.ca/foxed/index.php?page=rx7manual
Old Mar 8, 2009 | 04:09 AM
well i found out that the trailing coils were giving spark so i switched them and the car started......now the leading coils are still not giving spark anybody know why?.....i have the trailing spark wires on to the leading spark plugs.....dont know if its bad but the car seems perfect which is really weird...
Old Mar 8, 2009 | 11:46 AM
Aaron Cake's Avatar
Engine, Not Motor
How are you testing for spark?
Old Mar 8, 2009 | 01:14 PM
pulling the wire off the coil and hold it next to it to actually see the spark......you also hear a ticking noise.....
Old Mar 8, 2009 | 01:15 PM
i only got it from the trailing coils not the leading
Old Mar 8, 2009 | 02:20 PM
Kentetsu's Avatar
Check all the connections to the leading coil. If you need a new coil, you can usually find them for about 20 bucks on Ebay...
Old Mar 12, 2009 | 02:02 AM
drifter403's Avatar
my best guess is you need new coil packs... new wires and plugs would be smart to replace too... or it could be a simple bad battery alternator or starter...
Old Mar 12, 2009 | 10:14 AM
Aaron Cake's Avatar
Engine, Not Motor
A bad alternator or starter will in no way prevent the leading coil from sparking.
Coils also rarely fail, so it's best to test them with the procedures in the FSM before assuming they are bad.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
