Engine light flashing.... Need help..
Old Mar 3, 2009 | 03:11 PM
wment's Avatar
MD Engine light flashing.... Need help..
I have a 91 NA efi 13B auto trans. The engine starts and idles fine. When trying to drive it after it is warm it will only accelerate to about 20mph and gets real mushy and rough. The engine light flashes 6 times then repeats. I am new to the RX7 and havent read anything here to help me out so far. Can anyone help me diagnose this.
Old Mar 3, 2009 | 08:06 PM
RotaryRocket88's Avatar
Top Down, Boost Up
http://www.banzai-racing.com/FD&S5_error_codes.htm
You need to know whether the flashes are "long" or "short".
If it's 5 long and 1 short, then it's a problem with the fuel pump resistor/relay. All the other 6 flash combinations seem to be with components that should not affect much.
The resistor/relay is near the air box, and can be tested as per the factory service manual (FSM).
Old Mar 4, 2009 | 01:02 PM
wment's Avatar
The car is still covered with snow from the foot plus we got on monday. Ill check the light to see if they are long/short flashes. Thanks
Old Mar 6, 2009 | 01:56 PM
wment's Avatar
The battery was dead but after charging I got the car started. The Check Engine light was on solid and the word HOLD was flashing slow and steadily. I moved the car around a bit and let it warm up then shut it off. I restarted it again and let it run for a while and noticed that the Check Engine light was off and HOLD was not flashing. The engine revs fine up to about 2k but over that it goes
HMMMMMM sput HMMMMM sput HMMMMMMM sput .
It sputs about once every 2 secs. The sput get worse the higher it revs and it has very low power.
Any suggestions??
Old Mar 6, 2009 | 03:13 PM
Top Down, Boost Up
It sounds like limp mode from the OMP failing. That would be engine codes 20, 26 & 27.
Old Mar 15, 2009 | 03:42 PM
wment's Avatar
If the MOP is failing would premixing be an option? If I would premix, what ratio fuel/oil?
Old Mar 17, 2009 | 03:43 PM
Top Down, Boost Up
Premixing will make up from the lack of oil going into the combustion chambers, but it won't do anything to stop the ecu from running the car in limp mode (if that really is it). You will need to replace the MOP/OMP if it is bad, but first check the codes and be sure that's really it.
Old Jun 16, 2009 | 10:41 PM
Gregory Casimir's Avatar
well im having the same issue and i'm gonna get some leds tomorrow but what does the flashing engine check light mean though? I can't seem to find out what that means?
Old Jun 17, 2009 | 02:20 PM
Top Down, Boost Up
You don't need LEDs to pull engine codes on an S5. The flashing of the check engine light IS the code. Click the link I provided above, and count the number of flashes you see.
Old Jun 17, 2009 | 03:28 PM
Really!?! i didn't know that. and the link you posted is for the S5 correct? the thing is that the car it ran before i change my tps and now it doesn't even hold a bad idle like it did before i changed my old tps and now my maf sensor is outta wack? when its plugged in the car doesn't stay on but when its unplugged it runs like crap.
Kyo
Apr 13, 2019 09:24 AM
gtcd
30
Aug 19, 2015 02:44 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
