SS Braided Fuel Lines Adapter Question
Old Feb 28, 2009 | 09:45 PM
NaturalSmooth's Avatar
T04Z 13B-RE
Just checking to see how people have adapted the stock hardlines on the fuel pump assembly to SS braided.
I don't really want to use regular fuel hose to connect the hard line to a hose barb/-AN adapter.
Any info or pics?
Old Feb 28, 2009 | 09:57 PM
SirCygnus's Avatar
whats going on?
how about searching?
Old Feb 28, 2009 | 10:03 PM
TweakGames's Avatar
FD pro licensed driver
What no more carburated fuel lines Smooth? That takes all the fun out of it!
Old Feb 28, 2009 | 10:10 PM
T04Z 13B-RE
Thanks search ****. Guess I wasn't using the right words in the search.
Originally Posted by Aaron Cake
I replaced my entire fuel system with braided stainless. There are no stock fuel lines left in the car, and the connections to the tank are made with AN bulkheads.
If you intend to keep the hardlines, there are many options.
You can flare the ends of the stock lines if they are in good shape. 37 degree flaring tools are avilable, and a nut slipped over the line will secure it to standard AN fittings.
You can braze or weld on an AN flare adapter. Make sure the lines are totally clear before doing something like this and disconnect at the tank end as well. Can be dangerous.
There are sleeves designed to allow connection of standard lines to AN fittings. They have a flared end to match the AN fitting and then a nut that screws overtop. I think Earls has them.
Be careful with the summit kit as it does not mention fuel injection. Some of the sleeves are rated for low pressures only.
Old Feb 28, 2009 | 11:53 PM
BLUE TII's Avatar
Rotary Motoring
Use a metric female tube to -AN male flair fitting.
I use Swagelok fittings. When using a swaged ferule fitting make sure the fitting is harder than the tube you are putting it on for proper swaging.
Attached Thumbnails SS Braided Fuel Lines Adapter Question-swagelok-fitting.jpg
Old Mar 1, 2009 | 10:35 AM
arghx's Avatar
rotorhead
I'm not sure why you care, J-rat put down 550rwhp on stock fuel lines with a non ball bearing version of your turbo (T04R/T67)
Old Mar 2, 2009 | 02:44 PM
T04Z 13B-RE
I would have just used the stock lines if it came with any. They were missing when I bought my car, so rather than source some old crappy ones, I'm just using ss braided.
I think I am going to just use the 37 degree flaring tool to connect the hard lines from the assembly to the new braided lines.
Old Mar 2, 2009 | 02:54 PM
classicauto's Avatar
Crash Auto?Fix Auto.
http://store.summitracing.com/partde...5&autoview=sku
Those.
With these
Then you'll have to make an AN line going from the fuel pump "cover" to the pump.
Old Mar 2, 2009 | 06:40 PM
arghx's Avatar
rotorhead
I've never seen anyone make custom AN hardlines. I am looking at this chart of tube diameter and thread sizes:
http://www.anplumbing.com/thread.html
Would you just take the stock tubing, which I think is closest to 6AN, and then use the flaring tool on that one end? And then use a die to cut a 9/16-18 SAE thread?
Old Mar 2, 2009 | 10:07 PM
T04Z 13B-RE
I would have done the bulk head fitting route, but the problem is that I have an intake walbro pump, which can't use threaded fittings, so that's why I will just convert the stock hard lines to -5an, like in the link below.
http://www.honda-tech.com/showthread.php?t=1527379
Old Mar 3, 2009 | 09:03 AM
You can slide AN hose over a flared hard line. You can do that on the pump outlet.
Or use those gay little fittings that are an AN looking fitting with a hose clamp on them.
I slide my -6 line over the outlet on the fuel pump and put a hose clamp on. Been on there for years without leaks or fuss, changed the filter a number of times.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
