JDM engine question.
Old Feb 28, 2009 | 08:13 PM
JhnC's Avatar
Hi, I am planning to buy a 13B-T S5 TURBO II jdm engine including these parts:
Complete Head
Complete Block
Intake Manifold
Exhaust Manifold
Injectors
Throttle Body
Power Steering Pump
Sensors
Fuel Rail
Alternater
Distributor
A/C Compressor
Turbo Charger
Top-Mount Intercooler
Clutch
Flywheel
ECU
Wiring Harness
RWD Manual Transmission
Also I'm planning to find a TII body (chassis, shell, w/e without the engine & transmission) for it, but if i were to use an N/A body what do i need to change or do in order to get everything working. Sorry if this is a dumb question, but I'm new to the whole rx7 deal. Thank you for your time.
P.S I tried searching this forum and havent find a good answer and the rotaryresurrection page kinda confused me. Also please if you cant or dont want to answer the question dont post remarks saying do more research, and blah blah blah.
Old Feb 28, 2009 | 08:54 PM
Icemark's Avatar
The only issue with those parts will be that you will need to re-wire the existing non turbo harness if you don't get a 89-91 Turbo coupe.
And the tranny mount.
If you don't get a Turbo body, you will also need the Turbo rear end or a custom drive shaft.
Old Feb 28, 2009 | 09:23 PM
JhnC's Avatar
So if i get a 89-turbo coupe it would pretty much be plug n bolt?
Old Feb 28, 2009 | 09:29 PM
Icemark's Avatar
Any 89-91 Turbo would be the least amount of work
82streetracer
Aug 23, 2015 09:28 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
