im sooo confused.
Old Feb 27, 2009 | 03:12 PM
hatedbywife's Avatar
Unhappy im sooo confused.
ok for starters. ita an 89 n/a gxl with 194000 miles its rough to say the least.
so i threw a fan belt at 140 (not a good idea) and burned up the housing seals. so im in the process of pulling the motor now. i have stripped it of all the intake,ac,power steering, etc. pulled the oil pan. pulled the starter. pulled three tranny bolts on top n two on the bottom. unbolted the engine mounts... what else do i have to do to get this damn thing to break loose of the tranny
Old Feb 27, 2009 | 03:23 PM
Icemark's Avatar
If you are pulling the motor, it is generally easier to pull the motor and tranny together.
Old Feb 27, 2009 | 03:27 PM
i was really hopin u wouldnt say that. the broblem being is that my cherry picker consists of me n a few buddies. but if i do pull both what is the best way to seperate them..
Old Feb 27, 2009 | 03:53 PM
Question cleaning internals?
so basically the internals look like they r caked in carbon covered with rotted oil.... how the hell do i get it off of the rotor housings? the oil was easy. but what bout this carbon buildup. its like tryin to scrape asphault with a leaf rake. i swear there has to be an easier way.
Old Feb 27, 2009 | 05:17 PM
Icemark's Avatar
Simple Green Heavy duty Purple cleaner and a pressure washer.
msilvia
28
Apr 14, 2016 12:58 PM
c0rpse
16
Sep 25, 2015 11:33 AM
risingsunroof82
Sep 9, 2015 08:06 PM
doritoloco
Sep 5, 2015 12:41 PM
AREITU
Apr 22, 2002 04:20 PM
