Marvel Mystery GAS TREATMENT?
Old May 23, 2002 | 07:39 PM
dwillms's Avatar
are you guys putting Gas Treatment in your OIL????
or do my canadian tire not carry the marvel mystery oil, oil treatment...
Old May 23, 2002 | 07:50 PM
supergoat's Avatar
Eggs are like fowl cheese
They make both.
Old May 23, 2002 | 08:13 PM
Amur_'s Avatar
Refined Valley Dude
MMO is a gas treatment that some of us throw in with an oil change (like I did a few weeks ago.) It's kinda like giving your OMP an enema.
Old May 23, 2002 | 08:47 PM
dwillms's Avatar
Hahahha Gas treatment in your oil....Heheh something tells me this will **** my rex up good... No? - Confused -
Old May 23, 2002 | 08:52 PM
Audiofight's Avatar
The name is Marvel Mystery Oil.
The name doesn't always mean what the product is.
Apple Jacks ring a bell?
Old May 23, 2002 | 08:55 PM
dwillms's Avatar
Yeah the company is called "Marvel Mystery Oil"
So their product line goes:
Gas Treatment
Oil Treatment?
So I just live in a lame as country with gay stupid stores that dont carry the oil treatment?
-Daryl
Old May 23, 2002 | 08:58 PM
rx_7_driver's Avatar
YEAH THIS DOES SOUND LIKE IT WOULD **** UP YOUR 7
PUTTING GAS TREATMENT IN YOUR OIL ??????
I AM ASSUMING U R TRYING TO SAY IT WILL HELP CLEAN UP YOUR OIL SYSTEM IN YOUR ENGINE
GIVE ME SOME INFO ON THIS MM **** I NEVER HEARD OF IT BECIDES ON HERE
Old May 23, 2002 | 09:26 PM
dwillms's Avatar
Hmmm Turtle Car Wax OWNS Marvel Mystery Oil... Wow Turtle owns alot of sub companies...
-Daryl
Old May 23, 2002 | 09:42 PM
autocrash's Avatar
Now with more 1st Gen!
rx_7_driver.... SEARCH (top right corner...) (get ur own info) (And the button that says CAPS LOCK on it... try it some time, it does AMAZING THINGS )
Old May 23, 2002 | 10:13 PM
Gene's Avatar
10 lb. boost, 5lb. bag
I put marvel mystery oil in my gastank for a while, it helped clean some crap out of the motor i bet. plus it's good insurance against trashing the motor unexpectedly due to OMP failure. 4oz per 10 gallons is what they recommend. I was doing it religiously until I dropped the turkey baster i was measuring it with into some sand and didn't bother to clean it yet so haven't been using it...
Old May 23, 2002 | 11:14 PM
mprime's Avatar
MMO is ok to use in gas and oil it's a kerosine based additive cleaner and is safe in both. Just READ the big bottles label or do a search online there is plenty of things online about it. It has been around for a very long time and is used in marine and aviation use.
Old May 24, 2002 | 12:53 AM
I put it in my gas all the time. I'll put some in my oil when I do my next oil change. It says right on the bottle that you can add it to gas or oil.
Old May 24, 2002 | 01:21 AM
u don't have to be a dick about it
some one needs a beer
Old May 24, 2002 | 02:27 AM
wdwflash's Avatar
Marvel Mystery oil has been around a long time. I had a '58 MGA with a judsen supercharger. It had a valve cover with a reservoir on one end that you filled with Marvel Mystery oil(it said right on it to use MMO only), and a line lead to the supercharger. The MMO was to lube the micarta vains in the supercharger and the oil didn't seem to effect the running of the engine(it ran real clean.)
Old May 24, 2002 | 03:47 PM
asherwood's Avatar
Manufacturer's recommendations:
I called the US distributer of MMO (Turtle Wax) and he confirmed that the 12oz size was the same product as the larger ones! Try http://www.marvelmysteryoil.com and see where it takes you, follow the links to performance products and finally Marvel. There you will see that the product numbers take the form: #MM012
I located the Material Safety Data Sheet and it also lists the product codes MM010 through MM018 as being the same chemical composition. The guy that handles the calls for Marvel and CD2 (Rich) said the reason for the different sizes and labels is more for marketing convenience and recommended 1 12oz bottle for 15-20 gal of gas or when used as an oil treatment at the ratio of 10-25% of the total oil change.
I added 12oz to the fuel and 12oz to the oil and I'd say that the engine has never run smoother (at idle or revin' up) and even when it's in the higher gears the engine pulls harder too!
Old May 24, 2002 | 03:53 PM
blu_gxl's Avatar
yes, it helps if you can read to read the bottle and stop bothering me j/k
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
rattlehead
Sep 25, 2015 10:55 PM
