89 GTU troubleshooting
Old Feb 26, 2009 | 02:19 PM
jose18's Avatar
Exclamation 89 GTU troubleshooting
i have an 89 GTU .... custume intake but other than that all stock. the car starts fine...has new battery and has new charging system... but recently i doenst want to run... 126,000 miles. the car starts but if you try to run it kicks back and pulls and doenst want to accelerate... the engine revs up .....another small problem is it has a wierd idle... when the car is on, the RPMS move around and the car wants to die and fall flat on its face. if anyone has had this kind of problem you should help me out.
Old Feb 26, 2009 | 02:35 PM
dawicka2's Avatar
well rested,buffet o food
Could be a number of things.
Start with checking compression first..........then post results.
john ny
Old Feb 26, 2009 | 02:37 PM
RotaryRocket88's Avatar
Top Down, Boost Up
First address the idle problem. Take a look at this thread, NJGreenBudd's post #28 https://www.rx7club.com/showthread.p...26#post9000626. There's a nice summary of what you should do for a surging idle.
Once you've adjusted the mixture/airflow/TPS, see how the car reacts when you try to drive it. The TPS in particular can have an affect on many RPM/load conditions, so you may solve the acceleration problem(or at least make it better) in the process. Post details after you make the adjustments.
Old Feb 26, 2009 | 02:39 PM
jose18's Avatar
ok thanks i will get that compression test done and then check the TPS
Old Feb 26, 2009 | 07:39 PM
iceblue's Avatar
Passing life by
Check compression sounds like an apex seal. If good OHM out the BACV the TPS then refer to grounding issues with the ECU and grounding system in general.
Old Feb 27, 2009 | 02:13 PM
jose18's Avatar
if it where a ground problem wouldnt it blow a fuse.. cuz all are good
Old Feb 28, 2009 | 08:19 PM
iceblue's Avatar
Passing life by
No
Old Feb 28, 2009 | 11:35 PM
harley71105's Avatar
Fuel filter, maybe ?
Old Feb 28, 2009 | 11:38 PM
Rotary_Knight's Avatar
Does it run fine when you are in nuetral with the clutch pushed in? Then does it act up when you have the car in gear? Could be a pilot bearing. Need mas info!
Old Mar 1, 2009 | 04:37 PM
iceblue's Avatar
Passing life by
Why would a pilot bearing cause drive ability hesitation issues?
Old Mar 2, 2009 | 02:08 PM
jose18's Avatar
yeah it kinda does not wont to run right when it is in gear. but if i rev up the engine it dies.... i can hear a click noise in the solinoide valve area one off them klicks but only after it dies.... could it be the air flow meter ?
Old Mar 2, 2009 | 03:00 PM
iceblue's Avatar
Passing life by
its hesitating under a load. ohm the tps outand then refer back to ground inadiquitys still sounds like pore groundings
Old Mar 2, 2009 | 03:07 PM
RotaryEvolution's Avatar
Sharp Claws
you can also check for codes... could be in limp mode due to a faulty OMP, but usually it would idle ok if so.
93FD510
Oct 1, 2015 02:00 PM
