help purchasing an 86 fc?
Old Feb 23, 2009 | 06:30 PM
ae86racer2's Avatar
hey you guys im thinking about purchasing a 86 rx7 gxl and the guy said it has 118,000 miles and it is in good condition. he also says that he as the factory and an electric fuel pump connected is that going to drain my gas quicker,and is it good for the engine? il need this car as a DD, the guys a mechanic and says this car is really good and should last. he purchased a new water pump and i had this preception that if the water pump is replaced the engine is no good? this will be my first rx7 and i want a good first expirence. thank you
Old Feb 24, 2009 | 09:19 AM
hanman's Avatar
I am not sure what you are saying about the fuel pump, unless you mean he has two fuel pumps hooked up? If so, I am not sure why you would do that on a N/A car, but I guess it wouldn't hurt.
Water pump is not an issue, unless the reason he is replacing it is that he overheated the engine, that would be bad. But, water pumps go bad with out overheating, so just ask him.
Old Feb 24, 2009 | 09:21 AM
Aaron Cake's Avatar
Engine, Not Motor
There is no reason to run two fuel pumps. By the mere fact that this guy would do something like that and that he is a "mechanic", you should be considering anything he says very suspicious after this point.
Old Feb 24, 2009 | 09:28 AM
ae86racer2's Avatar
here is the listing.
1986 mazda rx-7 13b rotary engine. Manual/Stock Shift.
Car has new rear main seals, spark plugs, spark plug cables, complete tune up, alternator with gaurentee, new ultamite battery, water pump, hoses, electric fan.
Has stage two racing clutch, headers, msd fuel electronic pump and the stock fuel pump. High performance gasoline lines. Dual 2 1/2 inch piping exhuast. Aluminum hood. Racing steering wheel.
Car has G5 clifford alarm system with talking speaker. 3% Window Tints. Interior in good condition. 118k original miles.
Took car to Dyno came out 190 hp to the wheels. Completely stripped of wieght
Old Feb 24, 2009 | 09:32 AM
ae86racer2's Avatar
he told me that it has never overheated and he usually takes it to the track once a month, but i want it for a DD and also to have some fun and i was wondering why it has two fuel pumps i just thought it was weird? thanks for the help
Old Feb 24, 2009 | 10:24 AM
Grappler's Avatar
Turbo on the brain...
I want to know where he got 190 Hp the N/a 1986 produces 146 Hp at the flywheel there is no way he is getting 190 at the wheels with just an exhaust...
Old Feb 24, 2009 | 10:36 AM
Aaron Cake's Avatar
Engine, Not Motor
Good enough. Don't know what an "ultimate" battery is, and the electric fan is probably pointless. If the fan is wired wrong, it will be a major headache. The fan is probably also the reason the car has a new alternator.
That will probably be a major pain to drive on the street, but it's hard to say because "stages" are a useless measurement.
"High performance gasoline lines"?! Ha ha ha...That's a good one. I'm going to use that quote from now on when I talk about BS mods.
The MSD fuel pump is a serious pump, and is probably increasing fuel pressure considerably. This will make the car run way too rich.
There is no way the car made 190 HP (220HP at the engine) to the wheels. None. Not a chance.
"Stripped of weight" probably means the interior is gone and it's a tin can. If you like driving around in a car that feels like it was pulled from a scrap heap, then it will save you the work of removing the stuff yourself. Personally, I like my car to not feel and look like a pile of junk.
Old Feb 24, 2009 | 10:54 AM
ae86racer2's Avatar
very interesting?!thanks for the info you guys. im going to still check it out because he says that he keeps up with the maintance, but with all the BS he was talking about i dont think i trust him, o and also i asked him if he premixes and he didnt no what that was!
anyways i think im going to pass on that one maybe il just keep looking for one in better condition.
Old Feb 24, 2009 | 09:52 PM
bigt240's Avatar
Are you looking for an N/A car or a turbo car?
Old Feb 24, 2009 | 10:02 PM
87rx7ftw's Avatar
87rx7ftw
im lost... so you mean theres 2 fuel pumps? if so then that would probably drain gas alot quicker then it should.
Old Feb 24, 2009 | 10:51 PM
hanman's Avatar
Yea, the HP numbers are a total fabrication, there's no way he is running that kind of horsepower on a lightly modded N/A.
As far as the premixing goes, if he has never removed the OMP and doesn't know what you mean by premixing, it's no biggie. It's not like you have to premix with our cars. It's just an option.
I would take a look at it, but I would be extremely cautious, there is too much BS in his description.
Old Feb 25, 2009 | 11:21 AM
ae86racer2's Avatar
im lookin for a NA, and i geuss you right if he never had to premix i geuss he woulnd have to no about it, yea i think i might still look at it but ill be cautious.
Old Feb 25, 2009 | 11:33 AM
minuteman7's Avatar
KILLIN EM SINCE 88'
CA
i bought my first 7 at 122,000 and that **** broke down! haha well not really, its running but i have so many problems, hey but no matter what look forward to a rebuild sometime in the close future.. anyways you should get it anyways work on it yourself!!
cto_2
19
May 8, 2018 08:15 AM
izzolaw
Sep 28, 2015 06:03 AM
