sounds like misfire
Old Feb 23, 2009 | 02:53 PM
GST7's Avatar
STANCE IS THE KEY
CA sounds like misfire
well i just dropped another 13b in my friends fc and i fired it up for the first time...
and it sounds like as if its misfiring......
dose anyone have any ideas besides the injectors???
THANKS
Old Feb 23, 2009 | 10:16 PM
farberio's Avatar
NASA-MW ST4
Did you check the timing?
Old Feb 24, 2009 | 01:42 AM
GST7's Avatar
STANCE IS THE KEY
yeah i did but it didnt help
Old Feb 24, 2009 | 09:04 AM
Aaron Cake's Avatar
Engine, Not Motor
Did you check the timing correctly?
What is the condition of the plugs and wires? Did the car misfire before the engine swap? Describe the misfire.
Old Feb 24, 2009 | 07:02 PM
GST7's Avatar
STANCE IS THE KEY
yes the timing is correct and the plugs are new ngk the wires are the same ones that were used when the motor sounded fine ...
before the swap the motor was fine...umm it has a rough idle and when you gas it...
it just feels like its taking in too much air and not enough gas...
i changed the injectors but it still dose the same thing....
Old Feb 25, 2009 | 12:12 AM
Sumospeed's Avatar
I think that this one is going to need more info about what swap you did, what Ecu you are running...what mods, has the car been tuned? ect. ect.
this is going to be kinda hard to diag over the internet
Old Feb 25, 2009 | 08:58 AM
Aaron Cake's Avatar
Engine, Not Motor
The car doesn't "idle" when you "gas it". By definition, it is no longer at idle.
How do you know it's running lean? Pull the spark plugs and examine them. White colour means too lean, tan is just about right, black is to rich.
How long did this car sit during the whole process? It is very common for injectors to fail due to sitting.
Describe how you checked the timing.
Have you checked for vacuum leaks?
Old Feb 26, 2009 | 02:22 AM
GST7's Avatar
STANCE IS THE KEY
ok guys i have figured out the problem at last pritty easy after every thing else...
ok i tried another ecu and it stared to run fine, then it idled all high at 2g's when all ready
warm, i found some vac leaks and now it runs great...
but now i feel a lag at 3500-4000 what can i do about that????
Old Feb 26, 2009 | 09:04 AM
Aaron Cake's Avatar
Engine, Not Motor
That's the 3800 RPM hesitation. Check your grounds.
http://www.aaroncake.net/rx-7/grounding.htm
Old Feb 26, 2009 | 02:43 PM
rx7keg's Avatar
Or get some new high qulity spark plugs that fixed my prob,
Old Feb 26, 2009 | 11:51 PM
young o's Avatar
Old Feb 27, 2009 | 02:59 AM
GST7's Avatar
STANCE IS THE KEY
alright thanks guys
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
