Top speed
Old Feb 21, 2009 | 06:16 PM
ICEY?'s Avatar
Top speed
I have an 89 n/a gtu and it tops out at 122...
is that because of the governor or is that all it has...?
what does yours top out at?
Old Feb 21, 2009 | 06:26 PM
freemanrx7's Avatar
^Hold On
I got my base 86 up to 130mph. I think the s5 cars weigh more which offsets the hp increase. Your motor might be tired as well. But your 122mph sounds about right.
Maybe with a drop-in k&n filter with new cats & exhaust you could get to 130mph+
Old Feb 21, 2009 | 06:35 PM
cmanns's Avatar
Smoke moar
I don't think RX's had a governor
Oh and damn i thought my gayomatic was slowing down my fc, all stock I was able to hit 119 with automatic.... car reaches 90 much quicker now after the few upgrades I wonder if I could hit 130 hmm
Automatic hits 119 and stops which is a few 100 rpm below when the 2ndaries kick in
Old Feb 21, 2009 | 06:37 PM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
are n/as really that slow stock.. wtf i think maybe some folks need a tune up..?
Old Feb 21, 2009 | 06:47 PM
KhanArtisT's Avatar
Former FC enthusiast
Something is wrong. The car should be able to redline 4th easily. There is no governer. When my car was NA I did this multiple times. Don't expect the car to accelerate very quickly...keep your foot to the floor and your eyes on the road.
Old Feb 21, 2009 | 06:48 PM
13bturbofc's Avatar
mmm doritos
if i recal correctly the GTU has 4:20 gears in the back while the GXL has 4:10 gears so the GTU would have a slightly lower top speed. i dont think those ratios are correct but i know the GTU has shorter gearing
Old Feb 21, 2009 | 06:53 PM
ICEY?'s Avatar
well my car isnt stock.. i have a single exhaust with no cat and a cheap air filter.
jsut thought the car would keep going and going
Old Feb 21, 2009 | 07:00 PM
SPENT-IT's Avatar
10/6
GTU is 4:30 ratio.
You are limited buy RPM now.
You will need a better fuel management and better manifold/air flow.
I forgot to add check to see if you AUX port actuators are working right.
Old Feb 21, 2009 | 07:01 PM
calicrewchief's Avatar
RotorHead
I had my 90 GTUs up to 144. The fuel cut on the Turbos is the only type of governor I can think of.
Old Feb 21, 2009 | 07:07 PM
Shainiac's Avatar
Originally Posted by SPENT-IT
GTU is 4:30 ratio.
This is incorrect. The "GTUs" had a 4.3 rear. The GTU, S4 and S5, had a 4.10 rear.
Old Feb 21, 2009 | 07:10 PM
cmanns's Avatar
Smoke moar
What rpm where you at and such?
I was going down highway 5, probably went WOT for well over 15-20 mins the temp started rising and the rpms wouldn't go higher, due to the 3rd gear of the automatics.
Old Feb 21, 2009 | 07:19 PM
ICEY?'s Avatar
dont really remember what rpm but it wasnt taht high...
Old Feb 21, 2009 | 07:23 PM
SPENT-IT's Avatar
10/6
sorry for the miss info.
Iv seen when someone is selling a rear from a gtu they say it's 4:3 .
Old Feb 21, 2009 | 07:43 PM
cmanns's Avatar
Smoke moar
Probably before the 2ndaries and 5/6th ports were open...tires properly inflated?
Old Feb 21, 2009 | 07:49 PM
Juiceh's Avatar
Saiga-12 Power!
I did a GPS read 120MPH in an 91 S5 vert with an S4 engine with non functional aux ports and a slipping automatic transmission.... If you can't top that I think something is wrong.
Old Feb 21, 2009 | 10:57 PM
RotaryWeaponSE7EN's Avatar
I gps'd the old gxl to 151mph. Still had some more tach room, but was getting closer to traffic. Lots of nice empty highways out here.
Old Feb 21, 2009 | 11:17 PM
13bturbofc's Avatar
mmm doritos
this thread is pretty dumb...its an NA its going to take 10 mins to get to top speed anyway whats the fun in that? the rush of maybe getting pulled over and sent to jail for going so fast on a public road..lol this thread fails
Old Feb 21, 2009 | 11:24 PM
NJGreenBudd's Avatar
rx-for-my-7
I got my S4 GXL up to 133mph with nothing but K&N intake and Pace Setter headers. I almost died but it was probably capable of more if we had a longer road. It was ***** quick up to 80 and then kinda stalled out and took a w hile to get past the dead zone but then took off again.
With my TII I have only been around one hundred mph cause i'm still tuning it. I need to get to my local drag strip so I can actually open up my car and get it dialed in.
Old Feb 22, 2009 | 01:17 AM
gxlbiscuit's Avatar
DONT FEED THE NOOBS
someone close this before this becomes a top speed ***** contest/festival...
Old Feb 23, 2009 | 05:21 PM
synergy7's Avatar
______
Bone stock your car should top out around 145 or so if it cant either you need a tune up or as stated or your engine is getting tired.
Old Feb 23, 2009 | 05:25 PM
sub9lulu's Avatar
238mph
let me find u a pic ...
Old Feb 23, 2009 | 05:31 PM
Icemark's Avatar
Maybe if it is a Turbo.
Top speed on an USA spec stock non turbo vert is about 125 MPH. On an USA spec stock non turbo coupe it is about 133-135, top speed on an USA spec stock Turbo is about 140.
And remember that 99% of the FC speedos out there are off (+ or -) about 5 to 10% at speeds above 100 MPH. So if you are basing your top speed by the speedo and not a GPS unit, then chances are you are not see the correct speed.
Old Feb 23, 2009 | 05:33 PM
93rx74lyfe's Avatar
Ronald..
Ive been over 160 many times just in a race with someone on the highway but Im not sure what it would be if I actually ran it all the way out.
Old Feb 23, 2009 | 06:45 PM
jake1191's Avatar
Pop Pop BANG FIRE!
i had my vert up to 137 on GPS 2 weeks after i bought it. With only k&n drop in and gutted cats
Old Feb 23, 2009 | 07:41 PM
rx-for-my-7
i dunno know about you guys but even though my GXL could get up to 133mph it was a useless fact. I mean simply that it took so long to get there that it didn't matter in most cases. Most of the roads are limited to 45 where I live and aren't any good for racing around, the highway is even too crowded for anything above 80mph most of the time. The best part of the rx7 power band was always from 10 to 100mph for me, after that it got too slow if you know what I mean.
My turbo fc is probably pretty fast all out but it stays under 60mph for the most part, it just gets to 60 really quick.
