Ignition coil going bad?
Old Feb 21, 2009 | 09:56 AM
Magpie57's Avatar
Rotarymember
UT Ignition coil going bad?
I was told that one of my coils os going bad. I thought that either they are good or they are bad. Either shes pregnant or shes not. When a wire goes bad the electrons stop. Otherwise the will pass through the wire. Am I on the right path here? They just dont fade away. Is there a test that I can perform with a multi-meter? Do we have an online service manual? Any one, any one, Beuler? Thanks for your help in advance, Mag
Old Feb 21, 2009 | 01:29 PM
HAILERS's Avatar
HAILERS
.http://www.cochran-racing.com/FSM/s4...CAL_SYSTEM.pdf
The third thread on this site has a link to the Factory Service Manual.
Or Google ROTORWIKI and look there.
The Lead coil does most of the work. It has but one coil. I'd look there is I thought I had a coil problem.
Make sure the TRAIL plug wires are on the right spots. Crossed TRAIL plug wires cause weird problems and failed engines.
Old Mar 14, 2009 | 09:42 PM
Magpie57's Avatar
Rotarymember
I changed out the 40 amp fuse under the hood and she started up. Thanks for your help guys! Mag
Old Mar 15, 2009 | 01:00 AM
arghx's Avatar
rotorhead
yeah ignition coils rarely fail on FC's. they are the strongest ignition system of any rotary car and are actually considered upgrades for FD's.
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
