Finalllllllllly my S5 rotors are finished.
Old Feb 20, 2009 | 01:33 AM
hurleysurf24's Avatar
wtf rotary wtf
Shaved off some weight, balanced, and milled out to 3mm. And lets just say it ended up being MUCH cheaper then racing beats set.
Old Feb 20, 2009 | 03:16 AM
RX7_Edgar's Avatar
**RVP**
Nice they look clean
Old Feb 20, 2009 | 08:09 AM
ITSWILL's Avatar
Wiring Nightmare
how did you balance them?
Old Feb 20, 2009 | 09:43 AM
Turblown's Avatar
Turn up the boost
You would be surprised at how often the balancing is done wrong though.
Old Feb 20, 2009 | 10:13 AM
wtf rotary wtf
im pretty sure i can trust the guy that did them
and yes ive heard horror stories about balancing gone wrong lol.
Old Feb 20, 2009 | 11:00 AM
FC3Sdrift's Avatar
Displacement Replacement
how much weight did you remove?
Old Feb 20, 2009 | 11:05 AM
classicauto's Avatar
Crash Auto?Fix Auto.
Looks good, was the weight removed for balancing only? Any of the lightened rotors I've seen have large areas behind the sideseal grooved milled down.
the fresh 3mm slots should serve you well
Now install them and come to DGRR
Old Feb 20, 2009 | 07:29 PM
wtf rotary wtf
from what i was told .. roughly one pound if i recall correctly
Old Feb 20, 2009 | 10:33 PM
RX7Tuner.'s Avatar
I really Schruted it
One pound? Someone's fishing and I'm not biting. You removed 1/19 of the entire rotor?
Old Feb 21, 2009 | 03:47 AM
wtf rotary wtf
like i said from what i recall. i dont know the exact weight that was taken out/off.
Old Feb 21, 2009 | 04:37 AM
RX7Tuner.'s Avatar
It honestly looks like from the pics that they were just balanced. The places where one would normally remove material are barely touched. But any material gone is a good thing.
Old Feb 21, 2009 | 08:05 AM
Bruceman's Avatar
Rotor Power Rules
not sure why you would lighten the rotors if you're not going to use a light flywheel
Old Feb 21, 2009 | 08:42 AM
beefhole's Avatar
Boosted. I got BLOWN!!!
You mean around 1/9...
Old Feb 21, 2009 | 09:23 AM
RX7Tuner.'s Avatar
Each rotor is 9.5 lbs. 1 lbs was claimed to be removed from both rotors or .5 lbs from each. .5 is 1/19 of 9.5
Old Feb 21, 2009 | 09:40 AM
fc3s91's Avatar
R.I.P Mark( Icemark )
That rotor has not been lighten. if you look by the side seals are there is no material taken away. Also were the roll pins are Racingbeat installs snaprings to keep the inner bearing hub from coming out. I think you got taken.
Thanks Robert
Old Feb 21, 2009 | 10:35 AM
beefhole's Avatar
Misinterpretation on my part.
Old Feb 21, 2009 | 07:31 PM
wtf rotary wtf
no weight taken from the side areas ... it was taken out from the inside
Old Feb 21, 2009 | 11:08 PM
fc3s91's Avatar
Do you have pics?
Old Feb 22, 2009 | 03:58 PM
wtf rotary wtf
i have the weighed amounts and pics of in progress (didnt receieve em yet) from the guy that did the work.
Old Feb 22, 2009 | 05:02 PM
K-Tune's Avatar
FD Daily
why are you using the stock flywheel? is this going to be a drag racer on slicks?
Old Feb 22, 2009 | 05:07 PM
kustomizingkid's Avatar
Lol... lightened rotors with a stock flywheel makes no sense to me...
Old Feb 22, 2009 | 05:17 PM
Juiceh's Avatar
Saiga-12 Power!
Thats the first time I've heard of that being done.. I would think removing weight from the outside areas would be much better than removing weight from the inside. All the lightened rotors I've seen have had material removed from the outside. It does look like your rotors just had some removed from the outside just for balancing..
Old Feb 22, 2009 | 05:39 PM
Rob XX 7's Avatar
FC guy
has your guy done other rotors the same way?
im no expert, but it seems that if I had a rotating mass that I wanted lighter it would be less stressfull on the rotating assembly if I removed the weight from the outer edges, this way there is less rotating mass.
Just discussing thats all.
Old Feb 22, 2009 | 08:21 PM
ITSWILL's Avatar
Wiring Nightmare
yeah they dont look like lightened rotors that I have seen, i am interested to see the pics of how it was done.
Old Feb 23, 2009 | 12:14 AM
wtf rotary wtf
was told that removing weight from the side seal could cause those areas to collapse under high rpm runs (keep in mind this is auto/roadracing .. so lots of high revs and on/off throttle constantly)
i wanted the benefits the flywheel had for the autocross purposes.
