Why was my coolant system pressurized?
Old May 23, 2002 | 07:41 AM
Samps's Avatar
Here's the story:
My car has never overheated, or has had any cooling problems of any kind. Well I removed all three intake manifolds and removed all of the solenoids and vacuum lines. I plugged up all of the openings and put it back together. I tried to start the car and it wouldn't start. I did the unflood procedure and it still didn't start. So I took the manifolds back off to check for something I might have done wrong; but found nothing. So I decided to check the injectors to see if they were leaking by jumping the fuel pump wires on the strut tower. Then just out of curiousity, I decided to remove the radiator cap. Well when I loosened up the cap it let out a nice whoosh and a little spray of coolant. I am puzzled as to why the coolant system could have been pressurized. I know that a bad water seal can creat pressure in the system but I have never had a coolant problem and can't see where I could have damaged the seals doing work on the intake. Does anyone have any input on what may be wrong or how I may have damaged the water seals? Is there any other way to create pressure in the coolant system without the car actually running and getting hot?
Old May 23, 2002 | 08:12 AM
Turblown's Avatar
Turn up the boost
that is wierd, i have never heard of this.
Old May 23, 2002 | 10:32 AM
Samps's Avatar
Is my car just evil?
Old May 23, 2002 | 01:44 PM
SaabGuy's Avatar
You do realize that the cap directly on the radiator is lower than the top of the cooling system. Not to say it should flow out, but it is possible.
Old May 23, 2002 | 02:09 PM
Samps's Avatar
The car has been sitting for alomst two weeks. It has not been started in almost two weeks. Now if you let a car sit for two weeks and then go outside and take off the radiator cap, there should not be pressure in the system, correct? I don't mean the coolant dripped out a little. It actually sprayed a little. Not much; just a little. But it deffintely had a buildup of pressure.
Old May 23, 2002 | 03:29 PM
'Vert in Vegas's Avatar
It sounds to me like your radiator cap has a excellent seal (PERHAPS TOO GOOD) and is working well.
If you have no overheating problems, or coolant loss , Don't Worry.
Old May 23, 2002 | 03:46 PM
Samps's Avatar
The cap is a mazda one i got from mazdatrix. It is only about two months old. Is it posible for a coolant system to hold pressure for that long? If so that is amazing considering how many places there is for the air to get out.
Old May 23, 2002 | 03:48 PM
nopistons's Avatar
I agree with Vert in Vegas. You may want to try a new cap in case the pressure release spring on your current one is acting strange. It should release at the pressure indicated on the cap. A shop with a pressure tester could check it for you.
Old May 23, 2002 | 03:55 PM
QC Motorsports
Has it been getting hot where you live samps? If so, when you have something in a container that is sealed and you heat it up the presure inside goes up as well. even alittle hotter than usual can do this. Its just a thought. But yeah it sounds like you have a hard sealing radiator cap.
Old May 23, 2002 | 06:11 PM
Turbo Timmy's Avatar
Professional Lurker
The cooling system is normally pressurized... Thats why they say don't open it when hot...
Old May 23, 2002 | 08:21 PM
Amur_'s Avatar
Refined Valley Dude
Last year my FC sat from January to July. I would try to run the engine once every 2-3 weeks (car was fucked up from an accident, engine was waiting to be transplanted.) I also checked the coolant every once in a while. And each time I took the cap off, there was a *bloop* of coolant that splurted out. At first, it kinda freaked me out, but my mechanic told me it was nothing special, and I have never had any heat/cooling related probs with the engine, b4 or since.
If the coolant blasted out when you took the cap off, be concerned. If it just kinda farted, don't worry about it.
Old May 24, 2002 | 07:26 AM
Samps's Avatar
It just kinda farted. Thanks for the info guys. I was getting a little worried.
13
Jan 9, 2018 11:19 AM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
