Haltech anybody using E8 with plug and play patch loom kit ?
Old Feb 19, 2009 | 01:36 AM
boostedfc3s's Avatar
1.3 liter piston eater
Going to a standalone this winter and came across this. Is anyone here using the patch loom kit ? How " plug and play " is it really ? If not what else is needed ? have you had any problems with it ? any input would be great. Thanks.
Old Feb 19, 2009 | 03:02 AM
C. Ludwig's Avatar
www.lms-efi.com
The plug part is a straight plug in installation. I would recommend you swap out the S4 TPS for either an S5 TPS and throttle body (my preference) or the Haltech TPS. The S4 TPS is narrow range and not well suited for a standalone.
The play part depends on the base map you start with and how well you, or your tuner, can tune. It's still a standalone and, even with a close base map, will need to be tweeked for optimal performance.
Old Feb 21, 2009 | 05:16 PM
mr_vaughn's Avatar
Chillin
i have this installed . But got it installed for me..
Only do it if your engine harness is in good condition.
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
TheAsset
Sep 5, 2015 04:36 PM
